Toymods » Tech & Conversions » oem valve stem seal color??
._T_.
oem valve stem seal color?? Fri, 02 January 2004 02:12 Go to next message
i've got a 4age head here to reassemble - and it actually has a new set of factory stem seals with it. only my engine manual is at home! so i'm wondering if anyone knows whether the brown seals go on the intake, the black on the exhaust? (or is it the other way around?)
much easier with the aftermarket kits as the seals are all the same type....
anyone know for sure?
T
IRA11Y
Club Member
Re: oem valve stem seal color?? Fri, 02 January 2004 11:43 Go to previous messageGo to next message
usually theyre all one colour or the other... ive only ever seen brown from toyota and some dodgy black ones from shit VRS kits like Aeduca
in any case they should all be the same, there is no difference between intake and exhaust
[Updated on: Fri, 02 January 2004 11:44]
Re: oem valve stem seal color?? Fri, 02 January 2004 11:53 Go to previous messageGo to next message
i honestly don't know abotu your seals, but Viton is usually brown or orange, and normal rubber seals are black.
the viton has higher temp capabilities (at least with O-rings)
so, based on that, i would be using the brown ones on the exhuast, and the black ones on the intakes.
if in doubt, call a bearing shop Wink
btw, i use silicon, viton and normal o-rings allthe time at uni Wink
Cya, STewart
._T_.
Re: oem valve stem seal color?? Fri, 02 January 2004 22:37 Go to previous message
thanks guys.
"normal" aftermarket ones are all black. from what i've found out the brown ones do go on the inlet side.
ta
T
Previous Topic:brake pads
Next Topic:is there such a car as an AE26 toyota or is it a typo in the article?
Current Time: Sat Oct 31 22:07:33 UTC 2026
Total time taken to generate the page: 0.0040221214294434 seconds
