Toymods » Tech & Conversions » Aftermarket gauge sender adapter sizes
waynewatson
Aftermarket gauge sender adapter sizes Fri, 02 January 2004 02:26 Go to next message
Ok, does anyone know what size sender adapters I need for:
4AGE Water temp,
4AGE Oil pressure.
The 3/8" adapter supplied with the water temp gauge sensor didn't fit (it's about 1mm too wide), so It's a good bet the oil pressure one won't fit either.
So, before I go out and order every size imaginable in 1/8" NPT -> metric, does anyone know what sizes are needed?
The gauges are spitfire, but that shouldn't be relevant, they both have 1/8" NPT sized senders (as most/all gauges of these types).
PS: mounting and wiring was a piece of cake.
PPS: I'd like to at least have the water temp working by the end of the month (sprints).
naten
campbelltown
Re: Aftermarket gauge sender adapter sizes Sat, 03 January 2004 16:21 Go to previous messageGo to next message
take you original senders down to pirtec they can match them up for ya, only cost me a few bucks
waynewatson
Re: Aftermarket gauge sender adapter sizes Mon, 05 January 2004 01:17 Go to previous messageGo to next message
Can't drive a car with empty cooling system.
According to VDO, all toyotas have:
Water temp sender - M16x1.5
Oil pressure sender - 1/8 NPT
Grega
melbourne.victoria.austra...
Re: Aftermarket gauge sender adapter sizes Mon, 05 January 2004 02:08 Go to previous message
can confirm 100% that the oil sender is 1/8NPT - was the same on my 2T even and on my 4AGE!
be careful with it though - as you may find the sender that goes in the hole is too wide and will foul on the block! my autometer one did so i mounted it elsewhere in my oil cooler plumbing.
not sure on the water one, i had a special made up by meridian motorsport for me...using an alloy speedflow fitting tigged to the original housing (coz the thread was knackered)
Previous Topic:21r extractors
Next Topic:Supra Wxx gearbox noise in 4th... common??
Current Time: Tue Oct 20 22:34:51 UTC 2026
Total time taken to generate the page: 0.091015100479126 seconds
