Classifieds » Parts Wanted » WTB Hilux LSD
13BTA22
WTB Hilux LSD Fri, 02 January 2004 03:12 Go to next message
Hey after the centre if I can but will consider a complete unit.
Cheers Pete
levinracer
Re: WTB Hilux LSD Fri, 02 January 2004 23:31 Go to previous messageGo to next message
no luck hey,i still have that centre if you are interested.
Brad 0419492236
diffman
Denver, CO
Re: WTB Hilux LSD Sat, 03 January 2004 01:01 Go to previous messageGo to next message
All Model Corolla Differential Spools
I'm a newbie but have I got something for you corolla drifters.
Chromoly Mini spools for 6.38" ring gear "S" third members.
$65.00 each
O.K. "what's a mini spool?", you ask. A mini spool replaces the spider gears and side gears in the differential. It is then pinned and locks the axles. Save about 2lbs. of rotating and un-sprung weight, (reducing rotating and unsprung weight are good things). It doesn't have clutches that wear out and need adjustment. Your tires will scrub in normal street driving but how many of us drifters are normal?
Chromoly or aluminum full spools for 6.38" ring gear "S" third members or 6.75" ring gear "T" third members
Chromoly full spool $195.00
Aluminum full spool $225.00
O.K. "Now what's a full spool?", you ask. A full spool replaces the carrier, which the ring gear mounts to, in the differential. It also locks the axles. But the full spool saves about 5lbs. of rotating and un-sprung weight, (remember those are good things). It also doesn't have clutches that wear out and need adjustment. And yes your tires will scrub in normal street driving but again it's about the drift, right.
Installation and complete third members available.
Diffman
E-mail lynn-marie@qwest.net
Steve_Reynolds
Gold Coast
Re: WTB Hilux LSD Sat, 03 January 2004 06:20 Go to previous messageGo to next message
May have one for you. PM'ed you.
Steve
Allan
Re: WTB Hilux LSD Sat, 03 January 2004 11:07 Go to previous message
hmmm commercial posting
Previous Topic:WTB ct9 Turbo exh. wheels
Next Topic:4age 86kw cams or mild cams
Current Time: Fri Oct 23 16:50:31 UTC 2026
Total time taken to generate the page: 0.0041220188140869 seconds
