Toymods » Tech & Conversions » Fuel Pressure Regulator 7MGTE
celicaboy_2000
Lismore, NSW
Fuel Pressure Regulator 7MGTE Fri, 02 January 2004 06:08 Go to next message
If your reading this and own a 7MGTE I need to know the part number listed on the top of the fuel regulator. The regulator is mounted on the fuel rail near the alternator. Also where is the fuel filter found on a MA70 Supra? Is it in the tank?
ViNcEnXo
Re: Fuel Pressure Regulator 7MGTE Fri, 02 January 2004 07:56 Go to previous messageGo to next message
My Soarer says: 23280 42010 (ND) 0721
celicaboy_2000
Lismore, NSW
Re: Fuel Pressure Regulator 7MGTE Fri, 02 January 2004 08:02 Go to previous messageGo to next message
Thanks ViNcEnXo, does anyone else have any input?
Allan
Re: Fuel Pressure Regulator 7MGTE Fri, 02 January 2004 12:00 Go to previous messageGo to next message
http://forums.toymods.org.au/index.php?t=msg&t h=25098&rid=93&S=c74217d1b0a00a8b458652974 38bfb76&pl_view=
7M-Brisbane
Re: Fuel Pressure Regulator 7MGTE Sat, 03 January 2004 01:31 Go to previous messageGo to next message
Fuel filter is in a prick of a place. Jack up the car, it's just in front of the fuel tank, mounted up to the floorpan. Absolutely horrible thing. It's also mounted on a weak bracket that you will probably bend while you try to undo it Smile
celicaboy_2000
Lismore, NSW
Re: Fuel Pressure Regulator 7MGTE Sat, 03 January 2004 01:55 Go to previous messageGo to next message
Allan, is the regulator you made is it a rising rate or does it just adjust the base pressure? (I dont know what im talking about so just correct me if im talking crap).
7M-Brisbane, Cheers ill have alook once I remove all the red back spiders Mad
I Still need to know what the part number is on top of the stock fuel regulator, Cmon 7MGTE owners Very Happy
Allan
Re: Fuel Pressure Regulator 7MGTE Sun, 04 January 2004 01:52 Go to previous messageGo to next message
to make it rising rate you would have to add another diaphram to have a larger area then the fuel side by the ratio of the ammount of extra fuel IE 2:1 would be double the size but if ya geting that extreame its time to get a tuneable ecu!
Allan
celicaboy_2000
Lismore, NSW
Re: Fuel Pressure Regulator 7MGTE Sun, 04 January 2004 08:16 Go to previous messageGo to next message
Allan, Ive got a aftermarket computer so tuning is no problem. Im going to get the motor running with the standard regulator then ill be getting a adjustable rising rate down the track to get full benefits out of my injectors (thats the plan anyway).
Allan
Re: Fuel Pressure Regulator 7MGTE Sun, 04 January 2004 10:46 Go to previous messageGo to next message
well you really should not need more fuel pressure if thats the case unless its got a stupid size turbo/N2O on it!
Allan
SUPRAGTE
North Sydney
Re: Fuel Pressure Regulator 7MGTE Mon, 05 January 2004 04:12 Go to previous messageGo to next message
Exactly, i put a Malpassi regulator on mine and it has made the car run sooooooo rich. Needs to be completely re-tuned for the fuel maps. Basically it ran soooo rich it was out of the sensors range on the dyno, after about 100kw it went flat-line at 10:1 all the way to 222rwkw.
Basically you don't need bigger injectors on a 7MGTE until you've got over 300WRKW!!!! TIP: Don't waste your money anyone...
celicaboy_2000
Lismore, NSW
Re: Fuel Pressure Regulator 7MGTE Mon, 05 January 2004 08:12 Go to previous message
I still need to know the part number for the regulator, cmon people.
Previous Topic:Car Pulling Under Brakes?!? AE86
Next Topic:Legalities of Bigport 4AGE into AE92 ?
Current Time: Tue Nov 24 00:31:50 UTC 2026
Total time taken to generate the page: 0.0054831504821777 seconds
