Toymods » Tech & Conversions » Trouble Code 6 on early 4age
HighRolla
Trouble Code 6 on early 4age Fri, 02 January 2004 07:17 Go to next message
After checking the fault codes on my 86 model corolla (4age - blue top) I found a code 6 - RPM Signal. With diagnosis "No Ne or G signal to ECU within several seconds after engine is cranked" (from haynes manual) with trouble area "distributor circuit ...starter signal circuit"
The engine seems to run fine. Starting the motor warm, the car sometimes stalls (not often though). The main reason I was worried about was with the TVIS system. Fully opening of the butterflies on intake occurs at 4400 rpm, If the ECU isn't getting the RPM signal I was worried these butterflies may stay closed. The car seems to make decent power - would you notice a bad top end if this was the case? Thanks
GZE-STYLE
Camden
Re: Trouble Code 6 on early 4age Fri, 02 January 2004 10:29 Go to previous messageGo to next message
TVIS only operates to get better low-end performance. I can just feel TVIS kick in. I'll check what my manual says for that diagnostic code.
HighRolla
Re: Trouble Code 6 on early 4age Fri, 02 January 2004 12:29 Go to previous messageGo to next message
Thanks for that. My manual is pretty ambiguous. I know the TVIS improves low end torque , but if it doesn't change operation at the higher RPM I thought maybe robbing kW. Can't really feel it kick in.
FKN16V
NSW, East Coast
Re: Trouble Code 6 on early 4age Fri, 02 January 2004 13:55 Go to previous messageGo to next message
You wont feel the tvis kick in as much as you might think, listen for it, you'll here the engine note change when it does open. Ill check my book for that code know.
FKN16V
NSW, East Coast
Re: Trouble Code 6 on early 4age Fri, 02 January 2004 14:14 Go to previous messageGo to next message
Start from here and follow the fi- numbers
http://www.toymods.org.au/cgi-bin/photo/index.cgi? album=/TechDocs/4age_book/efi&mode=viewpicture &picture=fi_25.jpg
If unable to try starting from here
and work your way through it.
Hope it helps
HighRolla
Re: Trouble Code 6 on early 4age Sat, 03 January 2004 03:43 Go to previous message
Thanks. I'll check the engine note. Looked at the code page which looks similar to what the haynes manual was saying, I'll see if I can figure it out. That code 6 sounds like there is a range of areas where the problem could be (distributor ciruit, distributor, igniter, starter signal circuit, ECU). Does anyone know how you go about troubleshooting? Car is running pretty well - might be best to leave it?
Previous Topic:Extermely Comprehensive, TOYOTA related LINK!!!!!!
Next Topic:1JZGTE - won't run. Heeeeeelp!
Current Time: Wed Oct 21 10:00:28 UTC 2026
Total time taken to generate the page: 0.0046720504760742 seconds
