Classifieds » Parts Wanted » ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember
people100
Rocklea qld
ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember Fri, 02 January 2004 23:39 Go to next message
as the subject says thats what im after. anyhelp would be great.
Snyper
Re: ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember Sat, 03 January 2004 03:43 Go to previous messageGo to next message
if you're putting an 18R engine into a TA23 you just need to change the engine x-member to one out of an RA23, as far as I know there is no different sumps for the 18r engines but the RA23 xmember bends forwards to suit the 18r engine.
Brendon
people100
Rocklea qld
Re: ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember Sat, 03 January 2004 03:59 Go to previous messageGo to next message
there are different sumps netween the 76 celica 18r and the 78ish coronas with 18r's in them. the corona has the sump mounted towards the front where as the celica has it in the middle. i have used my ta23 crossmember. I have lowered it about 30mm and then used some rx7 rubber engine mounts which joins the crossmember to the engine. It all worked out good to. I had to do it that was as i couldnt get a ra23 crossmember. except from some rip off dude who wanted alot for it. so if someone has the sump let me know please
CelicaRA45
nth ringwood, Victoria
Re: ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember Sat, 03 January 2004 09:09 Go to previous messageGo to next message
ra40 xmembers are the same i do have a frt sump but the pump is different 2 for the 18rg
people100
Rocklea qld
Re: ta23 workshop manual and 18r front well sump and pickup to suit ta23 crossmember Sun, 04 January 2004 00:39 Go to previous message
so do ra40 crossmembers fit in ta/ra23. If so ill just go that was as i have one sitting here.
Previous Topic:NEEDS Power-Steering lines for 7MGTE (mine leaks oil badly)
Next Topic:WTB ct9 Turbo exh. wheels
Current Time: Sat Oct 17 18:45:03 UTC 2026
Total time taken to generate the page: 0.0061841011047363 seconds
