Toymods » Tech & Conversions » extractors heat shield
rollin
Blacktown, Sydney
extractors heat shield Sat, 03 January 2004 00:14 Go to next message
hey guyz i currently have a fwd 4age corolla and was wondering what material would be best to use as a heat shield for my extractors ... coz like the damn thing getz so hot that it started to warp my brand new radiator ...
i was thinking of getting a metal sheet and covering my radiator with it between the radiator core and the extractors but i think it will warp that too ... so whatz my best option ??
Re: extractors heat shield Sat, 03 January 2004 00:20 Go to previous messageGo to next message
Heat shields are typically constructed from aluminium or steel sheet.
Re: extractors heat shield Sat, 03 January 2004 01:12 Go to previous messageGo to next message
yup, thin (<1mm) aluminium pressed sheets are commonly used, and for better heat sheilding, have two layers....
one layer will reduce radiated heat. two layers will much reduce the re-radiation of heat from the first shield...
maybe 5-10mm between sheets? (ie a nut on the bolt)
rollin
Blacktown, Sydney
Re: extractors heat shield Sat, 03 January 2004 02:19 Go to previous messageGo to next message
okies thanks alot guys ...
umm would i need to go to a special shop to get aluminium pressed sheets ?? or are they available from any local hardware store ??
ed_ma61
Lost in the K hole
Re: extractors heat shield Sat, 03 January 2004 06:38 Go to previous message
try obrien aluminium. right down your way too if i recall your location
Previous Topic:+20 offset on a 16x7 rim for MA61
Next Topic:4K twin SU setup
Current Time: Mon Oct 19 15:49:54 UTC 2026
Total time taken to generate the page: 0.0050590038299561 seconds
