Classifieds » Parts Wanted » WTB: heated O2 sensor (screw in type)
ed_ma61
Lost in the K hole
WTB: heated O2 sensor (screw in type) Sat, 03 January 2004 08:02 Go to next message
as in title
heated 02 sensor, screw in type (not flanged). doesnt matter what plug is on it really.
i will say 'to suit toyota' but i think theyre pretty interchangable.
new or used - just need to get one in and working - i need to fiddle...
ed
grande91
Re: WTB: heated O2 sensor (screw in type) Sat, 03 January 2004 08:26 Go to previous messageGo to next message
would that be(heated) 3 wire ur looking for?? if 1wire would do you i have one that was used for 2-3000ks on a 7mge........
CelicaRA45
nth ringwood, Victoria
Re: WTB: heated O2 sensor (screw in type) Sat, 03 January 2004 09:06 Go to previous messageGo to next message
ed i have 4 x 4 wire screw in type toyota 1s nearly new 70 each
Re: WTB: heated O2 sensor (screw in type) Sat, 03 January 2004 10:01 Go to previous messageGo to next message
Heya Ed,
i have Bosch and NTK 4 wire.
check your PM.
willwal98
Toowoomba
Re: WTB: heated O2 sensor (screw in type) Fri, 09 January 2004 09:49 Go to previous messageGo to next message
sorry to hijack the post. whats the go with the heated type? I have a single wire one (non heated obviously) on an MT-4 ecu and it's terribly inacurate and i'm sure it's because it gets too cold (have extractors) can I get a heated type (I assume all multi wired ones) and use that? do they just have one signal wire, and a +ve and -ve for the heater element? Any dangers/problems with using one and does anyone have one left Very Happy
CelicaRA45
Re: WTB: heated O2 sensor (screw in type) Fri, 09 January 2004 12:12 Go to previous messageGo to next message
still have the 4 left
willwal98
Toowoomba
Re: WTB: heated O2 sensor (screw in type) Fri, 09 January 2004 13:01 Go to previous messageGo to next message
whats the difference between the 4 and 3 wires?
ed_ma61
Lost in the K hole
Re: WTB: heated O2 sensor (screw in type) Fri, 09 January 2004 21:52 Go to previous messageGo to next message
hey glenn,
turns out mt AFR meter was drawing a load and thus making it look like the 02 sensor wasnt working. all fixed now, thanks Smile
as for willwal: youre pretty close to the money with what youve suggested. if a single wire is too far away from the head, it may not get hot enough to operate properly (minimum 550degC)
3 wire is:
+ve heater
-ve heater
signal
4 wire is:
+ve heater
-ve heater
signal
signal ground (rather than just earthing the signal wire through the body of the sensor, it has a dedicated wire to earth back at the ecu)
willwal98
Toowoomba
Re: WTB: heated O2 sensor (screw in type) Sat, 10 January 2004 06:05 Go to previous messageGo to next message
ah thanks. I might look around for a 3 or 4 wire one then.
Re: WTB: heated O2 sensor (screw in type) Sat, 10 January 2004 07:10 Go to previous message
willwal98 wrote on Fri, 09 January 2004 20:49
Ed's on the money there. dangers? you have another power wires running around?
they last for a long time. the Bosch ones i have are meant to last for 100,000km (according to Bosch, assuming ideal conditions or something)
i have a couple each of both Bosch and NTK 4 wire heated sensors. they have 18x1.5 thread (standard type)
they are $63 including postage, $60 for pickup.
pm me and i'll link ya to a pic of them.
Previous Topic:WTB front l/h gaurd bumper and lights for a ra28/ta23 etc
Next Topic:Wanted : Engine Loom
Current Time: Thu Nov 26 05:48:22 UTC 2026
Total time taken to generate the page: 0.054082870483398 seconds
