Toymods » Tech & Conversions » Car Pulling Under Brakes?!? AE86
Necros
Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 08:58 Go to next message
Hey Ppls,
Ive just changed the wheel bearings on the left front wheel on my AE86, and now when braking it pulls strongly to the right hand side.
Is there any reason why this would happen? Mabey the nut for the hub is too tight/loose? Ive done it up just past tight and backed it off about 1/8 turn.
Any help appreciated!
de_rift
Wollongong
Re: Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 10:58 Go to previous messageGo to next message
maybe the right front wheel bearing is stuffed too
Re: Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 11:11 Go to previous messageGo to next message
did you remove the brake caliper when you removed the hub? did you disconnect or accidentally loosen the brake line? it sound slike you may have done something to affect the LHS brake caliper. pull off the wheel, and get someone to push the brake pedal while you are watching to make sure it's all working properly.
check bearign tightness again, and compare to the RHS one..
also check tyre pressures....
HighRolla
Re: Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 11:38 Go to previous messageGo to next message
If you did do something with brake line it might be worth bleeding the brakes just in case, before doing anything to drastic atleast.
clubagreenie
1st street on the right
Re: Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 11:56 Go to previous messageGo to next message
Check you didn't replace the caliper with a twist in the line.
manipulate
Re: Car Pulling Under Brakes?!? AE86 Sat, 03 January 2004 12:20 Go to previous messageGo to next message
yeah im also going for brakes hear
qik22
Re: Car Pulling Under Brakes?!? AE86 Sun, 04 January 2004 07:46 Go to previous messageGo to next message
my celica did the same thing, i actually put the pad that was on the inside on the outside and vice versa, the pads were worn on an angle so the right side (which i did not pull apart) was using a full pad while the left wheel was only using 1/4 of the pad....
Necros
Re: Car Pulling Under Brakes?!? AE86 Mon, 05 January 2004 08:30 Go to previous message
Thanks for all the info guys.... I just replaced the right hand side bearings too!
Everything seems to be normal and its a much smoother ride now Wink
Previous Topic:2t-g
Next Topic:Fuel Pressure Regulator 7MGTE
Current Time: Sun Nov 29 14:40:05 UTC 2026
Total time taken to generate the page: 0.37105989456177 seconds
