Toymods » Tech & Conversions » high revs 1JZ
JZA70_R
Brunswick, W.A.
high revs 1JZ Sat, 03 January 2004 09:02 Go to next message
Hi, i was just seeing if other ppl's 1JZ does the same.
At startup my car revs at 2000rpm, now this cant be good for it when it is cold, is there anyway to overcome this?
BlackSupra
Re: high revs 1JZ Sat, 03 January 2004 09:39 Go to previous messageGo to next message
my 2jzge does the same
Re: high revs 1JZ Sat, 03 January 2004 09:59 Go to previous messageGo to next message
Most new cars have a fast idle when they are warming up, but 2000rpm does seem a tad high Smile
HighRolla
Re: high revs 1JZ Sat, 03 January 2004 12:13 Go to previous messageGo to next message
My 4AGE idles at 2000rpm for about a minute or so then gradually reduces to about 900 rpm as it warms up
manipulate
Re: high revs 1JZ Sat, 03 January 2004 12:15 Go to previous messageGo to next message
yeah thats normal for the cold idle
and yeah i agrea its not good for a cold engine
it makes me chringe
also 80's cars went through a period of having bullshit high cold idles
astinas coronas, blah blahb
revved to atleas 2500 rpm easy
like i said it made me chringe
however they were carby cars so u could manually turn down the cold idle
i spose youd have to programm the computer wouldnt u to turn down the cold idel on yours ?
Siktoy ra23
Plumpton/sydney
Re: high revs 1JZ Sat, 03 January 2004 12:27 Go to previous messageGo to next message
if you use good motor oil this should not be to much of a problem.
Use mobile one or somthing simaler and you avoid the risk of engine wear, If you block of you cold start valve you car wont idle when you first start it unless you hold your foot on the throtle
JZA70_R
Brunswick, W.A.
Re: high revs 1JZ Mon, 05 January 2004 10:00 Go to previous message
Yeah I am using mobil 1 but i still dont like the sound of that 2000rpm in the morning.....
Previous Topic:Can't find info on RT133 corona diff ratio
Next Topic:3tg compression ratios
Current Time: Fri Nov 20 12:47:32 UTC 2026
Total time taken to generate the page: 0.0048580169677734 seconds
