Toymods » Tech & Conversions » ae82/92 strut brace
WiLo
wollongong NSW
ae82/92 strut brace Sat, 03 January 2004 11:18 Go to next message
will a factory strut brace of an ae92 fit an ae82? what parts will be required only have the brace itself no nuts,bolts,etc
Scorpion
Menai area of Sydney
Re: ae82/92 strut brace Sun, 04 January 2004 13:22 Go to previous messageGo to next message
I think it unlikely.
The AE92 has 3 studs in the stut top in a triangular pattern while the AE82 has 3 but provision for an extra one and in a diamond pattern plus the top can be mounted in two different caster positions. I can show you if you are in Sydney.
NuGeN
Re: ae82/92 strut brace Mon, 05 January 2004 11:02 Go to previous messageGo to next message
How about the other way around??
An ae82 strut brace on an ae92??
Scorpion
Re: ae82/92 strut brace Mon, 05 January 2004 12:10 Go to previous message
I just had a look at our AE82 and AE92 side by side. It is not a matter of adjusting bolt holes or similar, they are basically not interchangeable. The bolts in the firewall are spaced very differently, the lengths of the arms are very different plus the patterns of the studs in the top of the strut tower are different and aligned to the body on different angles. I'd be happy to tell you that you can modify one to suit the other but I can't see how it could be done.
Previous Topic:urget opionions.
Next Topic:valve spring compressor for a 3SGTE
Current Time: Fri Nov 20 12:46:47 UTC 2026
Total time taken to generate the page: 0.029304027557373 seconds
