Toymods » Tech & Conversions » TA22 Owners !
T APLUS 22
TA22 Owners ! Sat, 03 January 2004 16:14 Go to next message
After upgrading the headlights and playing with the indicator switch to change between Hi/Low beam something puzzled me:
Is the lever supposed to be pulled toward or away from you to engage the highbeam?
On my '74 TA22 in the forward position it is in low-beam, however I think this maybe wrong because to use the 'flash' feature to high it is not possible without actually turning them on fully.
Whilist in the high-beam position (closest to me) I can pull the lever a little toward me again which messes with the high/low again. Which makes be think that the most rearward position for the lever is actually for low beam, and you can just pull it a bit to 'flash' the high-beams. Then push the lever foward for full high beam.
Does this make sense? is the former example I gave the way its supposed to be? The car was rebuilt before I got it, so I believe the wiring may have beem messes up a wee bit.
If no sense can be made of this then someone tell me what their standard lights switching pattern is.
Cheers, Jacob
Re: TA22 Owners ! Sat, 03 January 2004 16:19 Go to previous messageGo to next message
normal operation i think would be to have the middle position as low beam. then pull toward you to 'flash high beam', or push forward to have 'high beam on'
yup.
sound slike wires are crossed.
T APLUS 22
Re: TA22 Owners ! Sat, 03 January 2004 16:35 Go to previous messageGo to next message
thanks mate. Thought I'd confirm it. Have you a ta22 and are talking from experience? Or using logic which I did to come to the conclusion it was ...WRONG
manipulate
Re: TA22 Owners ! Sun, 04 January 2004 01:34 Go to previous messageGo to next message
no i had a TA22 and hes right
its like most cars
middle low beam
pull towards for flash
push away for high beam on
ta2272
Re: TA22 Owners ! Sun, 04 January 2004 01:45 Go to previous messageGo to next message
ill confirm that pull towards to flash middle is low beam and push away for constant high beam when light are on.
Jason
what light did you put in im alos looking at upgrading.
peewee
adelaide
Re: TA22 Owners ! Sun, 04 January 2004 05:00 Go to previous messageGo to next message
and another confirm here, and interested to know what you used for the upgrade
T APLUS 22
Re: TA22 Owners ! Sun, 04 January 2004 10:49 Go to previous messageGo to next message
I wasn't saying his idea was wrong btw, if anyone made that assumption. I was just pointing out how my logic was probably the same as his (oldcorollas), and it is logic that I used to realise mine was stuffed Very Happy
[Updated on: Sun, 04 January 2004 10:49]
Grega
melbourne.victoria.austra...
Re: TA22 Owners ! Sun, 04 January 2004 19:06 Go to previous message
yup. same here, forward (towards you for flash) and backward away from you (towards front of car) for permanently on Smile
Previous Topic:Tapping into the sump ...
Next Topic:rough cost of hilux-pug-corona brake conversion
Current Time: Tue Oct 20 14:56:42 UTC 2026
Total time taken to generate the page: 0.011425018310547 seconds
