Toymods » Tech & Conversions » Tapping into the sump ...
krayzie
Tapping into the sump ... Sun, 04 January 2004 08:43 Go to next message
Im currently putting a turbo on my 4agte and wanted to know how some of you guys ran your return line into the sump?
Did you take the sump off and the put fitting on or did you do it on the car?
My engines in and I dont really want to have to take it out again I dont have that kind of time.
Let me know what you have experienced and what you think is the best way to run the return line
Andrew
tin can
Re: Tapping into the sump ... Sun, 04 January 2004 08:54 Go to previous messageGo to next message
man i took mine off and i use the 86kw sump and the got a fitting welded to it inch to the left and 3 cm down
Re: Tapping into the sump ... Sun, 04 January 2004 09:03 Go to previous messageGo to next message
krayzie wrote on Sun, 04 January 2004 18:43
unless there is a port in the block that drains to the sump, then you gotta take it off and get a return line adaptor (alloy or steel) braised or welded onto the sump.
if you dont want to weld you could get threaded tube that you can wind nuts on both sides of the sump hole, but expect leaks and eventual loosening of the nuts.
either way, remove the sump - if you weld it in-situ expect to car to burn down to the wheels.
also, you want what ever is attached to the sump to be above the full oil level of the sump - if the drain from the turbo cannot breath or sees pressure, oil will be forced out of turbo bearings and seals (am not sure if this also applies to ball-bearing turbos).
charles.
Steve-AE86
Ademelaide, SA
Re: Tapping into the sump ... Sun, 04 January 2004 10:07 Go to previous messageGo to next message
i would do as above.
BUT>>>
it's possible that you could use a sump off a ae102/112 corolla, as long as you get the one with the oil cooler fittings attached... as far as orientation goes, it 'should' fit...don't quote me though.
it would look far more professional, but cost you a crap load...
krayzie
Re: Tapping into the sump ... Sun, 04 January 2004 10:16 Go to previous messageGo to next message
Damn i was hoping there was some way to do it without taking the sump off. Oh well when I put the new head on I will do the sump as well.
Do I NEED to run an oil cooler if the car is turboed?
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Tapping into the sump ... Sun, 04 January 2004 10:30 Go to previous messageGo to next message
You don't really want to use the standard oil cooler return fitting as a drain for the turbo, as most turbos use a 1/2" or so I.D. return line. You really want to have a fitting to suite your turbo's oil drain.
As for an oil cooler, you don't have to run one, but it'd be a bloody good idea, especially considering your climate, if you live in Australia (except maybe Tasmania). It's pretty easy to get hold of a standard oil cooling system & fit it.
feral4mr2
Bundaberg, Qld.
Re: Tapping into the sump ... Sun, 04 January 2004 12:02 Go to previous messageGo to next message
Freak you can use a hammer and punch to put a hole into the sump with-out any metal going inside. the sump will just open a hole up like when a bullet goes through metal.
then you can get the oil return pipe brazed onto the sump...
Smile
TE72_Turbo
Re: Tapping into the sump ... Sun, 04 January 2004 12:16 Go to previous messageGo to next message
Just make sure you position it as high as you can on the sump wall (as thechuckster mentioned) or you will have dramas as I do with oil getting past the rear seal of the turbo. Mine is positioned only 20mm lower than the mounting lip at the top of the sump, and I still have issues unless the oil is 5mm lower than the "full" mark on the dipstick.
krayzie
Re: Tapping into the sump ... Sun, 04 January 2004 12:49 Go to previous messageGo to next message
feral4mr2 - What you said is something that had crossed my mind. It sounds a bit bodgy but Im wondering if it will work doing it this way.
Also what kind of pipe should I use to make this return pipe?
Where would I get it from?
feral4mr2
Bundaberg, Qld.
Re: Tapping into the sump ... Sun, 04 January 2004 12:54 Go to previous messageGo to next message
TE72_Turbo wrote on Sun, 04 January 2004 22:16
same with mine. Laughing
krayzie, i got mine brazed onto my sump when i had it off after i drilled a hole.
but i have personaly seen it done with the hammer and punch on a gte that was in the car. seemed to work fine and still does.
i used some thin wall steel pipe that was the diametre i needed.
Scorpion
Menai area of Sydney
Re: Tapping into the sump ... Sun, 04 January 2004 12:59 Go to previous messageGo to next message
From a turbo-uneducated perspective, does the return have to go directly to the sump. Can you put a right-angled fitting in the oil filler cap or into the rocker covers ?
Re: Tapping into the sump ... Sun, 04 January 2004 13:10 Go to previous messageGo to next message
Sure you can stick a drain in the cam cover - but only if the turbo's mounted about a foot above the bonnet Twisted Evil
I really would suggest taking off the sump and torching in a fitting, I just used a common plumbing fitting on mine, then some blue ('aeroquip') hose back up to the turbo. Simple, cheap and it works! But taking the sump off REALLY is a good idea if you can manage it, you may not have to take the engine out of the car if you're REALLY crafty/agile Cool
Re: Tapping into the sump ... Sun, 04 January 2004 13:39 Go to previous messageGo to next message
The oil coming out of a turbo is whipped up into a frothy milkshake after going through the turbo bearings which spin at 100,000 rpm or more, and it's non-pressurised to boot. This means the oil drain needs to have a direct downhill route to the sump, and the drain tube needs to be a large diameter. You certainly can't push it uphill into the cam covers!
Re: Tapping into the sump ... Sun, 04 January 2004 15:00 Go to previous messageGo to next message
Whatever you do, don't make the drain tube 7/8" - it's a total prick of a size.
You could drain the turbo oil to a collection pot (where it can "defroth") and then using a high temp electric oil pump, pump it up to the cam cover. You could use an oil level switch (from a 2JZGE) to trigger the oil pump.
Grega
melbourne.victoria.austra...
Re: Tapping into the sump ... Sun, 04 January 2004 18:59 Go to previous messageGo to next message
i had brazed into my 2T sump a fitting for a auto trans cooler (from a radiator) - looked fine after bronzing on there.
my 4AGE uses the 100kw sump and, has the return for the factory oil cooler (which i don't use)
10sec_rx7
Syndey
Re: Tapping into the sump ... Sun, 04 January 2004 21:55 Go to previous message
i did the one on my girl friends starlet while it was still on the car, just punched a hole in the sump and drilled it to size, then welded on the fitting,
then drained the oil and ran some cheap shit oil through a few times (just poured it in and drianed it didnt run the motor) pulled the oil filter apart and not a spec of shit in it
Dale
Previous Topic:Supra Wxx gearbox noise in 4th... common??
Next Topic:TA22 Owners !
Current Time: Wed Oct 21 01:04:14 UTC 2026
Total time taken to generate the page: 0.007533073425293 seconds
