Toymods » Tech & Conversions » Fuel pump and wiring question
demuire
Ipswich
Fuel pump and wiring question Sun, 04 January 2004 13:57 Go to next message
I'm currently wiring up my Corolla KE35 with a 4AGE in it, have a question regarding fuel pumps.
On the 4AGE, the fuel pump runs directly off the wiring harness (via the main relay I think - darn it where is the correct wiring diagram when I need it...). However because it's in a previously carby car, I have 2 fuel pumps - 1 facet style low pressure pump and 1 VL high pressure pump. Can I still run both of these off the wiring harness? I've been told fuel pumps don't take a lot of power, but am wondering if I should run these off a relay...
Also, wiring up the chassis and something strange is happening. I've wired in the 12V+ into the main chassis harness, don't have my starter, head/tail light, flasher relays yet so obviously those things don't work yet. Most other things seem to work (stop lights, radio circuit, interior light, clock etc). However, whenever I try to run any motors (heater fan, windscreen wipers, windscreen washer) the motor doesn't run, but instead the dash indicators (not the actual indicators - just the dash ones) turn on. However, if I unplug it completely from the loom and apply 12V to it, it runs. I've looked and looked at the wiring diagram, can't see any reason for this to happen. Even when it's wired up if I turn it on (and it doesn't work, dash indicator turns on instead) and put a volt meter across it, it reads 12V. But the motor isn't running.
Any ideas? Is this because I don't have the relays in yet?
T APLUS 22
Re: Fuel pump and wiring question Sun, 04 January 2004 14:51 Go to previous messageGo to next message
would now be a bad time to say
"its just gotta be a bad earth" ? (I think so)
Anyway, I've been looking at the two pumps current draw myself and was directed to:
http://www.bcae1.com/
to help me out. I reckon it will answer my questions when I come around to asking them again.
Hope it helps you too, thank 'septembersquallindustries' if your answers lie within.
demuire
Ipswich
Re: Fuel pump and wiring question Sun, 04 January 2004 16:22 Go to previous messageGo to next message
Hmm, you're probably right about the bad earth, will check my loom again to see if there are any earthing points I'm meant to earth. I wonder why all the lights etc work but not the motors... Bizzare Smile
Re: Fuel pump and wiring question Mon, 05 January 2004 03:07 Go to previous messageGo to next message
are we talking about your wiring to the 12 pin plug on the ecu?
if you are i can help identify what you do and dont need to connect. By the sounds of it you might be wiring up things to ELS2(or ELS1) when you dont need to.
Let me know, i worked it all out when i did the 4age into the AE71.
PS- big or smallport?
demuire
Ipswich
Re: Fuel pump and wiring question Mon, 05 January 2004 03:10 Go to previous messageGo to next message
Karl: small port. And umm... can't remember if it was a wire to the ECU, but remember seeing it on the wiring diagram that I got off club4AG (that surprise surprise I still can't find my printed copy). I think it came off the "main efi relay" or something to that effect.
By the looks of it (from the wiring diagram from memory) the only thing I don't connect is the a/c wire (since I have no a/c and no intention of getting it)? Everything else sounded important... Dammit, I have to find this diagram (it's got my notes on it and stuff)
[Updated on: Mon, 05 January 2004 03:11]
Re: Fuel pump and wiring question Mon, 05 January 2004 03:22 Go to previous messageGo to next message
yeah well at least you arent 20000km's from your notes!!!
FROM CLUB4AG:
1 B-R B1 EFI Main
2 R-W Batt BATT
3 Blu-G CCO Exhaust Temp Sensor
4 G-R FC Curcuit Opening relay(fuel)
5 G-W ELS1 Stop Lamp Switch
6 R-Y ACT A/C Amplifier
7 B-R B EFI Main
8 R-Y W Check Engine Lamp
9 R EGW Exhaust Temp Warn. Lamp
10 B-W A/C Air Conditioner clutch
11 V-W SPD Speed Sensor (instrument panel)
12 B ELS2 Idle Up Diode
NOTE: the ones in red are the only ones that i connected. ELS2 is the idle up control diode for electrical loads such as headlights, wipers etc. I didnt connect it for simple ease, and i have my idle running at about 1000rpm (also have no cold idle up water thingy)
so tell me how you connected the rest.
[Updated on: Mon, 05 January 2004 03:27]
Re: Fuel pump and wiring question Mon, 05 January 2004 03:23 Go to previous messageGo to next message
tends to be common to control fuel pumps via a relay - saves having the ECU switch (or send-to-earth) a high current load.
also, EFI pump relays often have a current limiter built in so the pump doesn't suck away precious power when you're idling or trying to start the engine. This tends to require two relays, one to switch power-to-pump on/off, the other to send current direct, or thru a big resister (current limiter).
also 2, by using a relay to drive the pumps, there's no fuse between the ECU and the relay, only betwen 12+ and the pump.
charles.
demuire
Ipswich
Re: Fuel pump and wiring question Mon, 05 January 2004 03:55 Go to previous messageGo to next message
karl: hmm, I have a feeling my pinouts are a little different (small port) but I might be wrong. I haven't actually wired it up yet, still trying to finish the chassis wiring. I've only gotten as far as looking at the diagram and labeling all my ECU pinouts.
I'll check the resistance on the pumps and work out how many amps I need to run both pumps and put a relay in Smile
thechuckster: are you saying there's a special sort of relay for efi fuel pumps? So I can't just use a normal like... horn relay?
Thanks!
Re: Fuel pump and wiring question Mon, 05 January 2004 05:47 Go to previous messageGo to next message
demuire wrote on Mon, 05 January 2004 13:55
you can use normal relays to turn them on/off, but the loom on my 1G-GTE had a 'fuel pump relay' - that was controlled by the ECU and fed from the circuit opening relay for a 12V+ source.
the wiring diagram here on page 1 of this PDF <http://members.optushome.com.au/mkhala/red_celica/ 1G-GTE_info/1g_gte_ecu_wiring.pdf> shows how it's wired up for the 1G - but the principal would be the same (i hope)
depends if you want the main pump to do the 'low power use' thing - but if you think your electrical system has enough capacity regardless of engine revs then don't bother. (But base your highest-current-requirement estimate on a worst case scenario (night-time in rain, passengers, hi-beam, engine under heavy load, etc.)
charles.
demuire
Ipswich
Re: Fuel pump and wiring question Mon, 05 January 2004 05:51 Go to previous messageGo to next message
Charles: Yup I get you. However the small port 4AGE doesn't have this relay (I think the big port one does). The relevant wiring diagram for the small port 4AGE is:
http://www.club4ag.com/faq%20and%20tech_pages/Tech %20Photos/AE92_Japan_Late_ECUa.jpg
*edit* oh yeah and karl looks like the 12 pins are the same as what you mentioned before... I think I was going to wire up all of them except the air cond stuff, exhaust temp and speed sensor. Then again I haven't really had a good look, I might not hook up the stop lamp switch or the idle up diode either... I'll see
Thanks!
[Updated on: Mon, 05 January 2004 05:55]
Grega
melbourne.victoria.austra...
Re: Fuel pump and wiring question Mon, 05 January 2004 06:11 Go to previous messageGo to next message
fook, AFAIK the 100kw motor also uses a circuit opening relay (as the witz eludes to)
its the thing marked "G" in the diagram dude.
be careful with the spec of ECU you have. i have a 100kw one here and its jap spec and the pinouts are VERY different to the aus spec 100kw one....
[Updated on: Mon, 05 January 2004 06:12]
demuire
Ipswich
Re: Fuel pump and wiring question Mon, 05 January 2004 06:16 Go to previous message
grega: yes i know. but it doesn't have the fuel pump relay like in Charles's diagram.
The pins and colors on my ECU match the ones in that diagram (apart from mine missing a few things like TEMS suspension controller etc), so I would assume I have the correct one...
Previous Topic:temp controller for thermo fan?
Next Topic:ae101 seats into ta22
Current Time: Mon Nov 23 15:21:56 UTC 2026
Total time taken to generate the page: 0.019380807876587 seconds
