Toymods » Tech & Conversions » head work worth doing ??
rollin
Blacktown, Sydney
head work worth doing ?? Mon, 05 January 2004 01:05 Go to next message
heyz just wondering if you guyz think this is worth doing ...
for $1500
serviced head
port and polished
adjustable cam gears
i cant remember the rest but thatz the main that will be done to my head ...
what possible gains will i have from this ?? and will i need to replace my injectors and fuel pump ?? and or what else would i need to upgrade ??
[Updated on: Mon, 05 January 2004 01:09]
Re: head work worth doing ?? Mon, 05 January 2004 01:24 Go to previous messageGo to next message
what engine, what type of cam gears?
on the surface it sounds like a good deal
and your injectors and fuel pump should be fine, depending on how worked your engine already is
rollin
Blacktown, Sydney
Re: head work worth doing ?? Mon, 05 January 2004 01:46 Go to previous messageGo to next message
itz a fwd 4age bigport ... and itz a corolla Embarassed ...
im not quite sure what type of cam gears but it will be done by Hi Comp in Mitchenbury near Mnt Druiit
my current 4age is pretty stock exept for the K&N and Headers
[Updated on: Mon, 05 January 2004 01:49]
Re: head work worth doing ?? Mon, 05 January 2004 03:03 Go to previous messageGo to next message
On a stock 4A-GE that will probably net you 2 or 3 hp if you're lucky. That's not much bang for your buck...
de_rift
Wollongong
Re: head work worth doing ?? Tue, 06 January 2004 01:37 Go to previous messageGo to next message
You could fit some 2nd hand high comp pistons for about that price..
Re: head work worth doing ?? Tue, 06 January 2004 14:53 Go to previous messageGo to next message
standard reco price for a head with twin cams should be around $240-250
i didn't think you would want to open up the intake ports any more... maybe a little off the exhausts, but i was under the impression that the ports were pretty good from factory.
not sure how much adjustable cam gears are, but i would not expect them to be more than a couple of hundred, even from japan.
$1500 sound a little exxy for my liking, but then again, it's not hard to do a port clean up....
so are you advancing or retarding your cams???
allencr
tallahassee FL usOFa
Re: head work worth doing ?? Tue, 06 January 2004 20:39 Go to previous messageGo to next message
who's doing the port & polish??
i think that with most characters claiming to do this, you've got a 33 1/3% chance of it actually being an improvement, and 66 2/3% chance of it being worse or the same.
even in OZ dollars that sounds pretty pricey with new valves & guides, and i've got a feeling it doesn't include them.
rollin
Blacktown, Sydney
Re: head work worth doing ?? Wed, 07 January 2004 13:54 Go to previous messageGo to next message
ahhh i see i see ... thanks alot for the help guyz but i think im going to pass this since i dont think it would be worth doing based on your oppinions ...
i was going to get it done at Hi Comp in metchenbury ... the guy der has done alot of 4age's though so yeah thatz why i was going to take it der ...
once again thanks for all the help ...
FKN16V
NSW, East Coast
Re: head work worth doing ?? Wed, 07 January 2004 15:28 Go to previous messageGo to next message
Try here, http://www.workin4u.com/jhh/castro.html
If you take the head off and send it to them, i think he said $880.
Ive been searching for a while for best bang for buck for my 4ag, and apart from forced induction this is the only thing ive found that even seems reasonable.
Re: head work worth doing ?? Wed, 07 January 2004 17:16 Go to previous messageGo to next message
Quote:
The engine in this Corolla is standard except for the cylinder head modified to STREET FORCE spec. At the time of head fitment the engine received new rings and bearings, the cams were left standard and the ecu unmodified.
The car went to a dyno and with minor adjustments to ignition timing , the engine produced close to 21kw increase at the wheels.
wow, 21kw at the wheels increase with stock cams?? the engine must have been totally shagged to start with... at least they did say it had a rebuild at the same time Wink
hmm, at toymods dyno day, i remember 86kw 4AG's were getting around 55kw atw...
then again, maybe they know something that no-one else does..
problem for all you 4AG kiddies is that your motor is half decent to start with.. and whatever you do, you are getting small % gains..
now if you start with a crap motor like a 4K, you can easily double the output Very Happy Razz LOL Very Happy
FKN16V
NSW, East Coast
Re: head work worth doing ?? Thu, 08 January 2004 02:32 Go to previous messageGo to next message
oldcorollas wrote on Thu, 08 January 2004 04:16
They also mentioned a 14.59 1/4mile at 152km, which i would say is worth $880.
Now i know driver skill is important but 14.59 is dam quick in my opinion for a n/a 4ag.
So im guessing they might know something other people may-not.
rollin
Blacktown, Sydney
Re: head work worth doing ?? Thu, 08 January 2004 03:23 Go to previous messageGo to next message
haha yeah thatz what i was thinking ... coz i have spoken to quite a few people and they said to get 10kw at the wheels extra i will have to spend alot of $$$ and that $800 does kinda sound really cheap ... dont get me wrong ... if they can increase my kw that much then i will definately do it ...
Re: head work worth doing ?? Thu, 08 January 2004 03:24 Go to previous messageGo to next message
If you think head work alone is going to get you into the 14's, you're going to be disappointed. I don't care how much they know, it takes more than head work to do that!
Re: head work worth doing ?? Thu, 08 January 2004 03:32 Go to previous messageGo to next message
fair nuff..
take the car to an independent dyno before the head work. then get the kw at the wheels increase IN WRITING from them before they do the work, and get them to GUARANTEE the increase they claim. then get the car dynoed after the head work at the same dyno with the same specs and variables and day temperature as before.
then go back and demand to have your money refunded Wink
seriously tho, they claim that atfer fully rebuilding a completely shagged motor (new rings and bearings), they got 21kw increase.. they don't say what the actual figure was beforehand, or after..
they seem to know what they are doing, but to expect 21kw atw with just porting, when the ports are already pretty good (we are talking a minimum of 20-25% increase in power here) is a fair whack.
maybe if they took out the spare tyre, and the seats and a bit more weight, it would help, but... then again, maybe i'm just cynical Wink
so what hp would be required to got a stock AEwhatever it is (82/92?) into 14's??? is that hp realistic with their claims?
be objective and critical with "performance claims" otherwise we'd all have those "supermagnet fuel molecule straighteners" Wink
rollin
Blacktown, Sydney
Re: head work worth doing ?? Thu, 08 January 2004 03:33 Go to previous message
chilax ... i was'nt aiming for 14's ... i know that is impossible with my kind of budget ... i was just wondering if head work was worth doing ...
Previous Topic:bolting onto back of 1gge exhaust manifold?
Next Topic:Electrical Problems In MA61
Current Time: Fri Nov 20 04:55:35 UTC 2026
Total time taken to generate the page: 0.012384176254272 seconds
