Toymods » Tech & Conversions » Sensors on 18RGEU???
sbyder
Ipswich QLD
Sensors on 18RGEU??? Thu, 01 August 2002 03:05 Go to next message
I just got my EFI from an EU motor that will be put on a RU motor. What sensors do i need to get the car running legally?
I've got a 3T computer to run it. And what are good injectors to upgrade to when i turbocharge it?-it's stroked to 2.2litre.
Thanks peoples,
Ben
Karl_skewes
New Zealand
Re: Sensors on 18RGEU??? Thu, 01 August 2002 10:35 Go to previous messageGo to next message
You will need to have an AFM.
You will need to have a Temp sensor, or you can trick this easily with a potentiometer, like a manual choke.
You don't need TPS.
You don't need Oxygen sensor.
These help for driveability, economy, and TPS definetely for full throttle power (>70% I think).
Real simple eh?
If it helps, I'll have a 2TGEU wiring diagram, 18RGEU wiring diagram, and some other 2TGEU stuff on the Garage Dori website in a week.
sbyder
Ipswich QLD
Re: Sensors on 18RGEU??? Thu, 01 August 2002 12:55 Go to previous messageGo to next message
whats an AFM? Air-fuel-???
If i don't use the Oxygen sensor, how will the computer still let the car run?/how do i bypass it?
Ben
Karl_skewes
New Zealand
Re: Sensors on 18RGEU??? Thu, 01 August 2002 20:41 Go to previous message
Just don't plug it in Razz
It's one wire with yellow plug.
AFM = airflow meter
That is really the only sensor you need to plug in, but you should really plug as much in as you can, barring the emissions crap.
Previous Topic:ECU pin outs
Next Topic:NA cams in SC
Current Time: Thu Nov 26 00:37:55 UTC 2026
Total time taken to generate the page: 0.0050859451293945 seconds
