Classifieds » Miscellaneous » 2T-G 1800cc
azorek
2T-G 1800cc Mon, 05 January 2004 09:35 Go to next message
Grumpy racing I have the engine for you...this is a monster
Toyota Twin Cam 2T-G (1800cc): Old school N/A horsepower, hassle free bolt in any ‘T’ series Toyota (Celica & Corolla). Engine ready for inspection, requires assembly and donor components (ie water pump, alternator etc). All receipts are available; this is a pipe dream that just didn’t materialise. The engine is located in Hampton Park, Melbourne, Victoria. List of work performed and parts:
Maxitorque Auto (Reservoir)
Bore & Hone (1800cc)
Surface Block
Crank Grind
Re-round Pistons
Resize conrods
Fit Welsh Plugs
Balance Engine
Four Plus Performance (Dandenong)
Full Gaskit kit (Suit 2T-G 1800cc)
Upper/Lower Chain
Upper/Lower Chain Tensioner
Gown Hindhaugh (Box Hill)
Reco Toyota Twin Cam Head
(Yamaha high compression head)
Paul Dan Auto (Hawthorn)
Engine Bearings
Piston Rings
Twin Cam Performance (Sean Moloney Richmond)
Machined High Compression Pistons
Miscellaneous
Twin Solex Carburettor (Requires Reconditioning)
Toyota 5spd Manual to suit
Toyota Celica TA 22 & 23 Australian manual (includes 2T-G engine assembly instructions)
Don’t pay up to $2000 from commercial wreakers; I am looking for any reasonable offer. Any urgent enquiries please email send_it_here@ziplip.com
ta2272
Re: 2T-G 1800cc Mon, 05 January 2004 09:53 Go to previous messageGo to next message
hey how much are you looking for.
jason
alex_ta22
Newcastle, Hunter Valley
Re: 2T-G 1800cc Mon, 05 January 2004 10:04 Go to previous messageGo to next message
too bad your in melbourne , this is just what i'm looking for
azorek
Re: 2T-G 1800cc Tue, 06 January 2004 08:36 Go to previous messageGo to next message
Hey TA22,
The receipts I have equal around $1521 not including the $800 I paid for the head!!! What I want is what I paid.......which isn't going to happen, so lets say around $1200, seems like a lot on paper, but these jap wreakers charge $2000 with little or no warranties and the engine is clapped to buggery!!!
With this one you have the added assurance that the engine will be assembled correctly and carbies go harder (quad throttle bodies) If you don't like carby convert them into EFI manifolds. Don't know if you've heard of Sean Moloney, he's an old pom who knows these things inside out he's estimated in the current spec (ie without modified cams) around 250 Hp. This isn't too bad before you add cams etc... and it's non turbo....I've seen these with the 1GZE supercharger push some great figures...
Anyway you probably know all this and an engine sitting in my garage isn't doing anything for me, so....make me an offer. Ps I can organise very competetive freight costs all across Australia.
T APLUS 22
Re: 2T-G 1800cc Tue, 06 January 2004 09:03 Go to previous messageGo to next message
shit. mate... prior to my engine conversion. I'd be on your doorstop in a flash.(with cash) man that hurts.
ps. I'm in melbounre, and yeah, if thats what sean est the HP to be..I'd believe it.
azorek
Re: 2T-G 1800cc Tue, 06 January 2004 09:16 Go to previous messageGo to next message
know anyone else who might be interested???
T APLUS 22
Re: 2T-G 1800cc Tue, 06 January 2004 10:57 Go to previous messageGo to next message
yes. Actually I do. As the recently formed president Razz (creator) of the Classic Celica Club of Victoria, I'll ask around.
bman
melbourne
Re: 2T-G 1800cc Tue, 06 January 2004 23:41 Go to previous messageGo to next message
makes me wish i hadn't spent nearly a $1000 on my 2TG head! Where were you 6 months ago!
T APLUS 22
Re: 2T-G 1800cc Wed, 07 January 2004 04:35 Go to previous messageGo to next message
bman wrote on Wed, 07 January 2004 10:41
timing is ridiculous aint it.
And azorek whats the CR ? 10:1 roughly?
And what injectors are you using?
At the estimated HP its still going to be more than my 2TGEU with Sc12 Supercharger on it. Wonder what that figure would be like with a modified throttle body(70mm)/plennum/inlet manifold. Coupled with EFI and aftermarket computer.
[Updated on: Wed, 07 January 2004 04:45]
TA22
Re: 2T-G 1800cc Sun, 11 January 2004 14:48 Go to previous messageGo to next message
could you please give me your number so that i could give you a call mihailov@123.net.au
CelicaRA45
nth ringwood, Victoria
Re: 2T-G 1800cc Mon, 12 January 2004 01:20 Go to previous messageGo to next message
mm 250 hp out of 1800 cc 8 valve engine what rev range 14000
4age formala altantic engine 1600cc 16 valve engine 240hp at 12000 rpm , the only way a na engine being 1800cc making that would be with a blower on it or turbo ,the group a and c motors made 185 hp and thats 2000 cc 2tg or 18rg motors and thats to 8500 rpm tops ,there 16valve race motors or heads they used made close to 200hp and 230 tops just letting you no. hp what people you could be a figure what a dyno makes but on a nother dyno might read lower
T APLUS 22
Re: 2T-G 1800cc Mon, 12 January 2004 03:34 Go to previous messageGo to next message
CelicaRA45 wrote on Mon, 12 January 2004 12:20
Well its got sfa to do with a Dyno as its engine (albeit an estimate) HP. so at the flywheel not the Rear Wheels.
CelicaRA45
Re: 2T-G 1800cc Mon, 12 January 2004 06:30 Go to previous messageGo to next message
well thats what im talking about here engine dyno not chassis dyno especially when a 2tg head with 460 thou lift cams will flow with flow bench 210 hp tops and thats with out inlet and thats been cleaned up or ported if you like ,also every engine dyno will be different
levinracer
Re: 2T-G 1800cc Mon, 12 January 2004 08:01 Go to previous message
Its truly amazing the horsepower figures come up with,i should have built a 2tg or 18rg rather then my beams....would have been a hell of alot cheaper for the similar power..... Laughing
Previous Topic:Wrecking 1975 rn20(?) Hilux Ute
Next Topic:AE 86 Disc Brake rear end
Current Time: Wed Oct 21 14:46:28 UTC 2026
Total time taken to generate the page: 0.056156873703003 seconds
