Toymods » Tech & Conversions » 20v exhaust manifold on a 16v?
slydar
20v exhaust manifold on a 16v? Mon, 05 January 2004 12:43 Go to next message
ok, heres what (i think) i know. i know you can go the other way (with mofication), i know the ports are the same, and i know there are 2 lugs that are differant. what i am wanting to know is if the flange on the 20v headers can be modified to work with a 16v head. or even possibly, although to my mind this is alot less desireable, modify the 16 head to work with the 20v headers. as far as the runners, i can fairly easily and cheaply modify these, as i have a tig welding friend. cheers for any input.
even if someone has a 16v out of a car in the brisbane area, i might be able to borrow the set from the seller to check.
p.s, these are intended to be fitted to a small port motor, though i am under the impression this doesnt make any differance, as the exhaust ports are the same?
purpleminiep
Mentone
Re: 20v exhaust manifold on a 16v? Mon, 05 January 2004 13:26 Go to previous messageGo to next message
The ports are exactly the same. It is only the two outside studs that need notching.
They should work a treat, pretty good looking extractors from the factory.
Brad
slydar
Re: 20v exhaust manifold on a 16v? Tue, 06 January 2004 00:14 Go to previous messageGo to next message
thats what i thought, my only concern is whether once the new holes are drilled, if theyll foul on the runners, or if theres enough material in the 20v flange to drill a new hole. what i need to know is the outter 2 studs that are moved, are they futher out on the 16v head, or further in, and by about how much?
._T_.
Re: 20v exhaust manifold on a 16v? Tue, 06 January 2004 01:54 Go to previous message
outside holes move outward about 10-15mm
T
Previous Topic:ST185 / ST205 / 3S-GTE wiring diagrams
Next Topic:gearbox oil level
Current Time: Fri Nov 20 10:25:22 UTC 2026
Total time taken to generate the page: 0.0039689540863037 seconds
