Classifieds » Parts Wanted » Parts for KE30/55/70 Corolla
crostek
Oyster bay NSW
Parts for KE30/55/70 Corolla Mon, 05 January 2004 22:35 Go to next message
Hi all just got myself a 1976 KE-30 rolla to run around in for a while, Don't what to spend a whole lot of dollars but just after a few little things hear a quick list:-
1. 4 internal door closer handles (black)
2. Rear mud flaps
3. front left indecator lens from gaurd.
Also after any help about a bolt in low cost front brake up grade.
Shane
0417 454 676
[Updated on: Wed, 03 March 2004 04:11]
Dominic
Perth,western australia
Re: Parts for KE30 rolla Fri, 09 January 2004 08:58 Go to previous messageGo to next message
hi mate,
i can get you a window winder,and maybe two door handles.
i havea KE30 2 door so that why i only got two...
that sway bars not a standard thing is it??
cant memeber if there was one under tehre or not..havent looked in a while...anyway,
i can get you the lock with a key aswell.
as for a a brake up grade,i have heard if you get AE86 top hats and then put them onto RT132 struts it works,then you can do the pug disk hilux caliper bit...i was going to do this before i scrapped my Ke30 project.
so i dont know if it realy works...
say $20 for teh winder handle sand lock??
where are you i am in perth wa but dont mind shipping.
cheers,
Dom
crostek
Oyster bay NSW
Re: Parts for KE30 rolla Sun, 11 January 2004 22:34 Go to previous messageGo to next message
$20 for the winder, door closer handles and lock would be great.
I got one winder handle from wreaker for $5, but a spare would be great.
You can COD the lot Through the post, put the cost of the post on the cod form at the post office. I will PM my address to you.
The rear bar is aftermarket or one from a KE70/AE71.
Thanks Shane
crostek
Oyster bay NSW
Re: Parts for KE30/55/70 Corolla Thu, 15 January 2004 01:06 Go to previous messageGo to next message
I after some more bit now
1. Repair book for 3K motor and KE 30 chassis
2. vac brake boster from 77 model KE car (this is the 6" aust type)
Re: Parts for KE30/55/70 Corolla Fri, 16 January 2004 08:47 Go to previous messageGo to next message
i have toyota yellow books for the 3K motor. what would it be worth to you?
Dominic
Re: Parts for KE30 rolla Fri, 16 January 2004 10:14 Go to previous messageGo to next message
himate,
those door handles,ar ethey the inside or out side ones??
cheers,
Dom
Dominic
Re: Parts for KE30/55/70 Corolla Fri, 16 January 2004 10:19 Go to previous messageGo to next message
i have the body and the chassis repair manuals(toyota yellows)for the KE30.
i was looking for $50.
cheers,
Dom
crostek
Oyster bay NSW
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 04:08 Go to previous messageGo to next message
still looking for most of these parts can any one help?
also looking for left front indecator lens from of the gaurd.
demuire
Ipswich
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 07:10 Go to previous messageGo to next message
I might be able to help with indicator lens and booster, and can also tell you about my brake setup (cheap upgrade). Will have to check what I have at home when I get home...
And no, stock KE30 doesn't have rear swaybar.
crostek
Oyster bay NSW
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 20:27 Go to previous messageGo to next message
demuire
The lens and booster would be great.
The rear bar I have source from irally just have been not able to get over to pick it up from him.
And the books are coming from Dominic and oldcorollas thank you both very much.
Demuire how much fro the booster and lens?
Shane
demuire
Ipswich
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 20:59 Go to previous messageGo to next message
Shane: Can't confirm if I have the booster and lens yet (I know I have a whole lot of stuff in a big box at home Razz), will have to confirm later - maybe tonight if I get the chance.
Brakes: Use XT130 or RT132 struts and brakes (including the hubs etc), lowered AE86 springs and AE86 top spring hat - this will give you standard ride height in the Corolla. You'll need to use your Corolla strut tops, and you'll also need to get the XT130/RT132 steering knuckles. Beware that this brake upgrade does give you slightly positive camber, but this can be fixed either by getting Pedders or another suspension specialist to "bend" your struts or using longer lower control arms (rumour has it Cressida ones are longer and bolt on), or camber tops.
crostek
Oyster bay NSW
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 22:21 Go to previous messageGo to next message
for the brakes I am going to try some AE71 panel van struts and brakes, these are the same as the AE86 sprinter, and look as if they will just bolt straight in???, I am still in need of some front springs in lowered or standard height to try out in the set-up.
I have not yet worked how big the master will have to be, but the car needs a new master any way and I will just have to see what will fit the apllication, and suit conversion to disc brake hilux alround converstion later on, if I keep the car long term.
demuire
Ipswich
Re: Parts for KE30/55/70 Corolla Wed, 03 March 2004 22:42 Go to previous messageGo to next message
Not sure about bolt in for AE71 struts. You'll probably have to use your KE30 strut tops as the AE71 ones are different (2 bolts will line up, the 3rd won't). I had some standard AE86 springs around before, not sure if I still have them.
For a master, if I'm not mistaken AE71 uses a 13/16. I think the KE30 Corolla has a 3/4. If you're going to go to Hilux brakes later you'd probably want something about 15/16.
If I'm not mistaken you can use the AE71 master, it should bolt onto your booster. Else if you want to go larger, have a look at my webpage. You'll probably be interested in the Mitsubishi Pajero or Nissan Navara/Petrol master cylinders.
irokin
Re: Parts for KE30/55/70 Corolla Thu, 04 March 2004 01:05 Go to previous messageGo to next message
hey mate
Im wrecking a KE30 at the moment (use the term loosly)
I can do you 4 black door openers (Front and rear) 3 window winders
left indicator lense looks ok...slight age cracks. I can throw in the right one too (looks brand new) if you want it.
my vac booster is the 76 type..dunno if thats any use to you...unsure of condition too.
anything else you want??
bloody_huge23
Re: Parts for KE30/55/70 Corolla Thu, 04 March 2004 08:15 Go to previous messageGo to next message
A low cost bake upgrade is also using the TA22 Front struts...
The discs are slightly bigger. Struts bolt straight in.
Thanx,
Adam
[Updated on: Thu, 04 March 2004 08:18]
demuire
Ipswich
Re: Parts for KE30/55/70 Corolla Thu, 04 March 2004 12:42 Go to previous message
I have booster and indicator lens. Booster has slight surface rust and the rubber boot is cracked, but it was working when it came off the car. Indicator lens looks fine.
However since irokin is wrecking his KE30 maybe better to get the lenses off him (as mine are just spares for me at the moment). Booster I'm happy to part with. Also I know irokin, so if you decide to get the bits of us we can probably post them all together to save money.
Previous Topic:WTB AE92 auto box
Next Topic:MA61 flares
Current Time: Sat Oct 24 20:36:49 UTC 2026
Total time taken to generate the page: 0.019557952880859 seconds
