Toymods » Tech & Conversions » 5S-FE Timing Belt
bubs
Jimboomba, Qld
5S-FE Timing Belt Tue, 06 January 2004 02:08 Go to next message
About to embark on this project this weekend on sillyca's ST184
there is not a lot of room in the engine bay, has anyone done the swap before and lend some pointers to make it a little easier?
regards
buddy
hippy
here
Re: 5S-FE Timing Belt Wed, 07 January 2004 05:50 Go to previous messageGo to next message
I had to strip off most of the pulleys from the surrounds...
there has to be a better way though.
bubs
Jimboomba, Qld
Re: 5S-FE Timing Belt Wed, 07 January 2004 22:09 Go to previous messageGo to next message
how do you mean strip off most of the pulleys from the surrounds?
FWDCelica
sydney,nsw.oz.
Re: 5S-FE Timing Belt Wed, 07 January 2004 22:44 Go to previous messageGo to next message
Big job.
Your best bet would be to buy a Haynes manual.
I ve done it on my ST162.(3SGE)Will take the best part of a day.
Disconnect battery.
Jack up Drivers Front side of car.
Remove Front Right Wheel.
Jack up the Drivers side of the motor to take weight of motor.
Take off the Engine Mount up on the Drivers side strut tower.
Remove Splash guards inside right hand wheel arch so that Crank Pulley is exposed.
Take off Alternator/Air Con drive belt + Power Steer belt.
Remove Top Cam Belt Cover so that Cam Pulley is exposed.
Remove Rocker/Camshaft Cover.
Put No.1 Piston on Top Dead Centre on Compression stroke.
Remove Crank Pulley. You'll need a Puller to get it off.
Remove bottom Cam Belt Cover.
Loosen Cam Belt Tensioner and remove old belt.
Put on new Belt and tighten tensioner.
Make sure Camshaft/Timing Marks/No.1 Piston are all OK.
(THIS IS THE TRICKY PART WHERE YOU REALLY NEED THE MANUAL)
If they aren't OK car won't start.
Installation is a reversal of the removal Procedure !!!
Or take it to Toyota and pay about $400 !
T.
bubs
Jimboomba, Qld
Re: 5S-FE Timing Belt Wed, 07 January 2004 23:18 Go to previous messageGo to next message
cool, thanks, we have the haynes manual, tell ya how it goes on monday
toyoda
Re: 5S-FE Timing Belt Wed, 07 January 2004 23:20 Go to previous messageGo to next message
And - Remember to take the Spark Plugs out when you wind the engine over to tension the belt - otherwise it will put too much strain on the belt.
Smile
bubs
Jimboomba, Qld
Re: 5S-FE Timing Belt Thu, 08 January 2004 00:06 Go to previous messageGo to next message
toyoda wrote on Thu, 08 January 2004 09:20
Smile
cool thanks
bubs
Jimboomba, Qld
Re: 5S-FE Timing Belt Thu, 29 January 2004 13:21 Go to previous message
done, took 3 1/2hrs and wasn't even rushing it, no where near as hard as i originally though Very Happy
Previous Topic:s/c problems
Next Topic:4Agze Compression Ratio
Current Time: Sat Oct 24 08:52:43 UTC 2026
Total time taken to generate the page: 0.0052320957183838 seconds
