Toymods » Tech & Conversions » 4A-GZE pistons specs?
Malkomv2.0
4A-GZE pistons specs? Tue, 06 January 2004 02:25 Go to next message
Can anyone give me the bore size, pin height, pin diameter and crown volume. I am also wondering how they are made, are the forged, coated with anything special?
Mal
Re: 4A-GZE pistons specs? Tue, 06 January 2004 05:01 Go to previous messageGo to next message
Malkomv2.0 wrote on Tue, 06 January 2004 13:25
Mal
the new piston that ppl chipped in to get so i could cut it up is part number
13103-16131 (this is a +0.50 piston)
skirt diameter = 81.5mm
pin height (pin centre to crown) = 30.5mm
pin diameter = 20mm
crown volume, not sure but will measure.
most of the crown volume appears to be in the valve cutouts.
i believe that they are forged. search the tech section for "piston analysis" i posted pics of the forging flow lines of the older type of 4AGZE piston.
i also believe them to be coated. i have not determined the type of material, but will soon.
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: 4A-GZE pistons specs? Tue, 06 January 2004 05:36 Go to previous message
The crown volume of the later 8.9:1 c/r pistons is 6.5cc.
Previous Topic:How to pick a Blown Head Gasket 7M
Next Topic:Power Window Motor & Regulator for 94 Sprinter
Current Time: Fri Nov 20 08:25:32 UTC 2026
Total time taken to generate the page: 0.0060479640960693 seconds
