Toymods » Tech & Conversions » Help Problem with aw11
Spanktown
Inside a giant turbo (syd...
icon2.gif  Help Problem with aw11 Tue, 06 January 2004 07:47 Go to next message
In my sc aw11 mr2, only in first gear when i take off from a standing start when the clutch is let out it makes a loud grinding/metallic sound untill the clutch is completely let out. This doesnt happen in any other gear when driving along, can anyone give me some ideas on what it could be?
[Updated on: Tue, 06 January 2004 23:45]
Spanktown
Re: Clutch Query? Tue, 06 January 2004 13:27 Go to previous messageGo to next message
Ben Wilson
Re: Help Problem with aw11 Wed, 07 January 2004 01:42 Go to previous messageGo to next message
Have you tried taking off in second gear?
Does the noise keep going if you pull the gearbox out of gear while it's making the noise?
Spanktown
Re: Help Problem with aw11 Wed, 07 January 2004 02:57 Go to previous messageGo to next message
i tried taking off in second gear and it did the exact same thing. Does that mean its the clutch? because more stress is being put on it when taking off from a stand still?
._T_.
Re: Help Problem with aw11 Wed, 07 January 2004 04:16 Go to previous messageGo to next message
clutch bearing??
Ben Wilson
Re: Help Problem with aw11 Wed, 07 January 2004 04:39 Go to previous messageGo to next message
Does it make the noise when you put in the clutch at idle, but, in neutral? If so, then it's probably the clutch thrust bearing as Toby suggested, once you're moving, it's probably still making the noise, but, you're leaving the noise behind.
Spanktown
Re: Help Problem with aw11 Wed, 07 January 2004 05:30 Go to previous messageGo to next message
if its in nuetral it doesnt make the noise at all, its a LOUD noise so you couldnt possibly leave it behind. sometimes you can feel the car shudder a bit. Also if i nurse it and let it out REALLY slowly with not alot of revs it wont make the noise
[Updated on: Wed, 07 January 2004 05:30]
Ben Wilson
Re: Help Problem with aw11 Wed, 07 January 2004 20:53 Go to previous messageGo to next message
I've gotta admit, you've got me beat with this one...
Possibly wheel bearings? I'm stabbing in the dark here. You might want to get someone to stand outside the car while you take off slowly and see if they can pick where the noise is coming from...
Spanktown
Re: Help Problem with aw11 Wed, 07 January 2004 23:47 Go to previous messageGo to next message
i think ill just take it to a clutch place... doh!
adamb131
Re: Help Problem with aw11 Thu, 08 January 2004 05:18 Go to previous messageGo to next message
Mine had a similar crunching grinding noise when the clutch was really worn. The same as you... only when taking off.
After a while the clutch was gone all together. Soon I wasn't able to change gears while the engine was running at all... unless I blipped to a sweet spot at around 3200rpm. Eventually I was pulling up at traffic lights... turning off the car... wait for the engine to stop spinning... put her in second... green light... hit the ignition with the clutch out and take off in second. When I got it fixed the mechanic said the bearing was mashed and there were springs and shit flying around in there everywhere... Very Happy
Spanktown
Re: Help Problem with aw11 Thu, 08 January 2004 07:32 Go to previous message
i hope thats the case, well i wish it was a loose bolt but if its the clutch its better than the gearbox.
Previous Topic:plugs and leads for 1g-gte
Next Topic:simmons f90 question
Current Time: Fri Nov 20 02:44:51 UTC 2026
Total time taken to generate the page: 0.0064170360565186 seconds
