Toymods » Tech & Conversions » 1ggue what do i need
RA65 Sleeka
1ggue what do i need Tue, 06 January 2004 10:22 Go to next message
I am getting a 1ggeu to put in to my ra65 celica What i need to know what gearboxes run up to them?(I have the W-55)
Also can i use the engine mounts from the 1ggeu in my car or do i have to move/cut them.
Do i have to change the sump??
Any other info Will be grate as i want to do most of the work my self.
Can someone please give me the run down on this engine tell me about it as in power, weakness
Thanks Scott...
Re: 1ggue what do i need Tue, 06 January 2004 10:35 Go to previous messageGo to next message
You will need a front sump for the 1G. These come from early water/air 1GGTE's or from a GA61 Celica XX.
Where did the engine come from?
As for the gearbox, you can use your W55, but you will need a new bellhousing to join them.
RA65 Sleeka
Re: 1ggue what do i need Tue, 06 January 2004 10:42 Go to previous messageGo to next message
Got/getting the from CelicaRA45 He had it for Sale last week so I'm getting it as i cant afford the insurance on a turbo one. Do you know anywhere i could get a bell-housing.
Re: 1ggue what do i need Tue, 06 January 2004 10:55 Go to previous messageGo to next message
I've got one if you want it, I'm in Perth but I don't mind sending it.
RA65 Sleeka
Re: 1ggue what do i need Wed, 07 January 2004 05:09 Go to previous messageGo to next message
the sump or the Bell housing Because the motor has a front sump
[Updated on: Wed, 07 January 2004 05:09]
Jag7799
Re: 1ggue what do i need Wed, 07 January 2004 05:17 Go to previous messageGo to next message
makes 119kw at flywheel.. at like 6400 rpm
and 180 nm of torque at like 5600
really its a piss weak slow engine.. but mines auto.. may be better with manual
Bugman
Re: 1ggue what do i need Wed, 07 January 2004 05:18 Go to previous messageGo to next message
still better than any R series motor.
but no rocket.
CrAiGzEE
south of the big smoke
Re: 1ggue what do i need Wed, 07 January 2004 05:57 Go to previous messageGo to next message
Jag7799 wrote on Wed, 07 January 2004 16:17
they are a hell of alot quicker in the celica than the soarers, robRa40s flys (well kinda) Razz
Jag7799
Re: 1ggue what do i need Wed, 07 January 2004 06:03 Go to previous messageGo to next message
yeah but his is manual.. id expect the manual to be alot quicker
only about 100kg weight difference in it
ra23celica
Re: 1ggue what do i need Wed, 07 January 2004 06:21 Go to previous messageGo to next message
If you get the bellhousing from 'Frank' any W55,W57 or W58 will bolt up to it. I have a W57 hooked up to my 1G-GZE, with a modified mid-rear sump from a 1G-GTE. The RA65 sump curves to the rear so you want a front sump and I think a pair of engine mount brackets that bolt on the the rear position on the block. I have a front sump here in Perth and a pair of rear position mounts as well too. PM me if you can't find these bits closer to you over there.
Mitch.
Jag7799
Re: 1ggue what do i need Wed, 07 January 2004 06:35 Go to previous messageGo to next message
lol if ur not doing it for bout 2 months.. you can have my front sump lol
Re: 1ggue what do i need Wed, 07 January 2004 07:06 Go to previous messageGo to next message
I've got a bellhousing, I've even got a full W57 attached to it if you're interested.
Testa_Dura
Re: 1ggue what do i need Wed, 07 January 2004 14:33 Go to previous message
if u havent already bought one i have a 1ggeu for sale with a w57 behind it. can still drive it if u like as i havent pulled it outa my car just yet. its running the standard ecu
Previous Topic:what 5spd will bolt strait upto a 4m with a 4spd (w40)
Next Topic:Custom gauges for supra
Current Time: Wed Oct 21 13:48:31 UTC 2026
Total time taken to generate the page: 0.0050158500671387 seconds
