Toymods » Tech & Conversions » AE86 dash lights
SW20R
AE86 dash lights Tue, 06 January 2004 12:56 Go to next message
There not working?
But the parkers and headlights are. Also i think the tail lights are. Why could this be? Also the climate control/heater isnt also showing
Steve-AE86
Ademelaide, SA
Re: AE86 dash lights Tue, 06 January 2004 13:57 Go to previous messageGo to next message
dimmer switch?
SW20R
Re: AE86 dash lights Tue, 06 January 2004 14:02 Go to previous messageGo to next message
nope tried that Very Happy
im thinking could be the wiring?
Steve-AE86
Ademelaide, SA
Re: AE86 dash lights Tue, 06 January 2004 14:10 Go to previous messageGo to next message
i used to belt the top of the dash in my car when the lights went out on the cluster...used to work for me...
what about fuses...or do they use the same fuse as the tail lights?
ae95
Re: AE86 dash lights Tue, 06 January 2004 14:11 Go to previous messageGo to next message
try tapping on the dial, mine always turns off every now and then
i think its a common problem with 86's
improvedae86
Re: AE86 dash lights Wed, 07 January 2004 05:18 Go to previous messageGo to next message
is the fuse blown , i thought that the fuse was the same one used for the tail lights or brake lights . i once had one that the dash light fuse , whichever one it was kept blowing , after changing the headlight switch and resoldering another one , pulling apart the car , tracing all wiring , i worked out that it was a faulty brake light relay { which isn't on the wiring diagrams } it was internally shorting causing the postive side of the dash light to melt a wire behind the drives side fuse kick panel . Remember that the dash illumination is negative , the postive is a constant in the circuit to . Also i hav seen allot of stereos installed using the postive to the heater control lights as a power / ignition overloading the wiring and fuse . i think the negative is a green wire from memory .
Best of luck ...
sticky667
usa
Re: AE86 dash lights Wed, 07 January 2004 05:23 Go to previous message
give the dash a good wack/kick and that should do the trick Very Happy
jeremy
Previous Topic:Fuel tank pickup
Next Topic:'91 Corolla seca CSI
Current Time: Fri Nov 20 08:01:04 UTC 2026
Total time taken to generate the page: 0.057329893112183 seconds
