Toymods » Tech & Conversions » Turbo size?
fatmr2
Turbo size? Wed, 07 January 2004 06:34 Go to next message
What sort of turbo am i going to need to get about 180kw at the rear wheels in a 4agte mr2?
CLG
Perth, Western Australia
Re: Turbo size? Wed, 07 January 2004 07:12 Go to previous messageGo to next message
Dude, do you realise that around 350HP at the crank???!!! Bugger the turbo, what are you going to do to the motor and gearbox to put that out reliably?
fatmr2
Re: Turbo size? Wed, 07 January 2004 08:57 Go to previous messageGo to next message
I know that Very Happy
Cool huh!
Considering they are getting 294kw atw in a 4agte ke70 ( zoom issue 71. And they say it is " Easy and Reliable " ) I don't think that asking for 180kw is a lot!
I've got everything else sorted out, I'm just not that good with turbo's so i need one that will give me the power i want just without too much lag.
Soarer
Wollongong
Re: Turbo size? Wed, 07 January 2004 11:07 Go to previous messageGo to next message
I've seen a Garrett GT30 put out 185kW from a 4A-G(T)E in a Celica.
CLG
Re: Turbo size? Wed, 07 January 2004 15:05 Go to previous messageGo to next message
fatmr2 wrote on Wed, 07 January 2004 16:57
Cool huh!
Have you seen the guy's on here with the "Performance, reliable, cheap ..., you can only have two of the three" signatures?!!! I'd suggest their "easy and reliable" is backed by a well worn wallet!
For what it's worth, I feel a GT30 on a 4AG may very well produce the figures you quest after, however turbo lag would make it misearable to drive. Why do you want so much power in a car that weighs less than a tonne?
fatmr2
Re: Turbo size? Wed, 07 January 2004 20:24 Go to previous messageGo to next message
CLG:
Number one my car actually weighs just over a tone!
And number two I'm not scared to spend the money!
You make it sound as though only people who do things on the cheap come to this site?
I'm building this car for my own reasons, if i wanted to hear i shouldn't do that to my car, I'm sure i can go and visit my mum!!!
Arent you supposed to be a car enthusiast?
SOARER:
Do you know if they experienced much lag? Also, I'm restricted by space a little bit, will it fit in my car?
Is that celica the green one with the yogi plates?
MR. 2
Parramatta
Re: Turbo size? Thu, 08 January 2004 01:43 Go to previous messageGo to next message
garette GT25 will do just waht ur after and not too much lag eith gt 30 way to big for a 1.6... however perfect for my mr2 ..... (comming soon)
onejayzed
Re: Turbo size? Thu, 08 January 2004 01:52 Go to previous messageGo to next message
fatmr2 wrote on Wed, 07 January 2004 19:57
Cool huh!
'easy and reliable' in ZOOM generally means "a lot of heartache and a number of girlfriends, about to reposess my house and half the build money wasted on R&D - but it runs sweet now!" Rolling Eyes
most of the dyno figures ZOOM print are oneoffs, eg lets put it up to 18psi for this run only, and then we'll set it back to 10 again for normal use. ZOOM are under the impression that once you have a dyno-printout /timeslip, your car is instantly that fast/powerful all the time.
and asking 180RWkW out of a 1.6L twincam fourpot is a lot to ask. my 1UZFE makes that much, and that 2.5x your engine in capacity with a similar redline. you can generally double the output of a factory engine without breaking it, anything above and beyond that you're looking at cams, pistons, rods etc.
the one that Soarer is talking about (180RWkW) has a fair amount of internal mods.
and 294RWkW out of a 4AGTE? that's approx 400hp at the wheels. that's 520hp out of a 1.6L, or 325hp per litre at the engine approx - or 2.5 times the power per litre output of a V8 supertourer.
there are only 2 engines that can take anywhere near this power on std bottom ends - and i'm talking theoretically here because i'm running on what i've seen the bottom ends put out (still not this much though) - is the 2.7L hilux engine (3RZ-FE) and the 1-2-3UZFE.
serious work will be needed, billet rods, forged pistons, ARP bolts, 20V head, individual throttles, lowlowlow CR (like 7.5:1).
you may produce the numbers, but i bet a stock 4AGZE with a GT25 off the side will beat you in a roll-on - because it will lack any kind of useable power and torque.
that said, if you just want a dyno monster then go for for it. who am i to tell you what you want...!
Sprinta
Re: Turbo size? Thu, 08 January 2004 01:57 Go to previous messageGo to next message
And just because people are using GT30's on their 4a's it doesnt make it 'good' as such.
Depends on what your after.. Do you want a car that can only go in a straight line?
Or do you want a car that will spool quick, hold to redline and still be able to fang it around corners which is what the mr2 was made for?
T28, or GT2530 are my picks
CLG
Re: Turbo size? Thu, 08 January 2004 02:13 Go to previous messageGo to next message
fatmr2, I'm not knocking your aspiration, but am a little bemused as to why you want that much power? I undestand the figure is acheivable, however personally I feel, as has already been quoted by others, it will not be a streetable package. Having said that, if your intention is for a dyno killer, go for it! Let us know what other mods you have plannned and how you go with the build?!
fatmr2
Re: Turbo size? Thu, 08 January 2004 04:20 Go to previous messageGo to next message
Like i said, I dont mind spending the money! Money really isnt an issue. I've already got a lot of the parts that i need. Im just looking for a turbo.
Put it this way.....My brother has a suzuki cappuccino which is 660cc, It put's out 104.5kw at the rear wheels, It weighs about 680-700kg.
There is my motivation!
I will spend what it takes to get my car to where it has to be.
I just figure that 180kw atw should be enough. Should it not be then i guess i will have to try again. In the mean time i like sprinta's idea of the t28/ gt2530.
Oh yeah, onejayzed, I thought these forums were here so i didnt spend all my money in r&d Razz and dont worry about the girlfriends, mine bought me a nice intercooler for christmas Very Happy
Thanks for all the help guys Smile
Caledwvech
Re: Turbo size? Thu, 08 January 2004 04:32 Go to previous messageGo to next message
660cc is putting out out 104rwkw????? Shocked Shocked Shocked
That was very nice of your g/f. Very Happy Did you give her any "hints"???? Very Happy
fatmr2
Re: Turbo size? Thu, 08 January 2004 04:54 Go to previous messageGo to next message
Yep. 104.5kw atr
If you want to see an article on it go to: ribera.customer.netspace.net.au/cap.htm
It will be in zoom magazine very soon as well.
As for the intercooler, Very Happy Yeah, i gave some hints Very Happy Very Happy
I'll be hinting for a new computer for my birthday Laughing
onejayzed
Re: Turbo size? Thu, 08 January 2004 06:18 Go to previous messageGo to next message
well, brand new roller T28s ex S15 silvia are only $1350odd NEW from Nissan....!
fatmr2
Re: Turbo size? Thu, 08 January 2004 06:45 Go to previous messageGo to next message
cool Smile
What's the difference between a bb t28 and a gt 28?
onejayzed
Re: Turbo size? Thu, 08 January 2004 07:32 Go to previous messageGo to next message
one comes from Nissan and cost $1350, one comes from a performance parts shop and costs $1600.
fatmr2
Re: Turbo size? Thu, 08 January 2004 08:32 Go to previous messageGo to next message
i see Rolling Eyes
So they are the same thing then?
Soarer
Wollongong
Re: Turbo size? Thu, 08 January 2004 11:29 Go to previous messageGo to next message
Yep, I was referring to Yogi's Celica.
Joshstix
Toymods Vice President
Re: Turbo size? Fri, 09 January 2004 05:53 Go to previous messageGo to next message
Take a look at this thread http://forums.toymods.org.au/index.php?t=msg&t h=24761&rid=218&S=dcb8b9c73a7d25fabffb57b7 79315d62&pl_view=&start=0#msg_211315msg_21 1315, this is how to get the power you're after plus a fair wack more.
rvrolla
Central Coast
Re: Turbo size? Fri, 09 January 2004 05:58 Go to previous messageGo to next message
CLG wrote on Thu, 08 January 2004 02:05
Very Happy
fatmr2
Re: Turbo size? Fri, 09 January 2004 06:19 Go to previous messageGo to next message
Thanks joshstix! I know the guy who owns that car, Ben. I forgot all about his car. I had the chance to buy his set up last year.
This just proves a lot of you wrong. That car runs standard internals. He's running a gt28 440hp turbo that comes on at 3200rpm. It runs something like 25-30 psi.
So my aim of 180rwkw is easy as. The bar has just been raised i think Smile
V8_MA61
Re: Turbo size? Fri, 09 January 2004 06:20 Go to previous messageGo to next message
first thing to consdier if you think you're gonna get 400hp you will need to do this:
New pistons
New rods
New crank
Massive head work
All custom exhaust
all custom intercooler
New box
NEw diff
New clutch
New computer
Weigh it up you're looking at over 15k id think
To get between 4-500hp out of my v8 i need to spend around 12k...and thats out of 5.0L..but with the parts i have it is possible to make more with a blower or turbo, because i built the bottom end tough.
SO 400hp out of 1600cc isnt that easy. Whether or not its late model with a turbo it requires a lot of work. time. and money.
[Updated on: Fri, 09 January 2004 06:22]
fatmr2
Re: Turbo size? Fri, 09 January 2004 06:27 Go to previous messageGo to next message
I never said i want 400hp? Onejayzed said it and he was talking about the car in zoom.
I said 180rwkw, and by the looks of things thats what i'll be gett'n Very Happy
V8_MA61
Re: Turbo size? Fri, 09 January 2004 06:30 Go to previous messageGo to next message
that is 321hp at the crank then
fatmr2
Re: Turbo size? Fri, 09 January 2004 06:34 Go to previous messageGo to next message
Cool, sounds like more when you say 321hp Very Happy
onejayzed
Re: Turbo size? Fri, 09 January 2004 07:08 Go to previous message
yeah i was talking about fatmr2's example, not his car.
rear wheel -> engine power is always sketchy. most people run off 30%, but i have seen figures as high as 40% (ie stock WRX - although that is 4WD, and most automatics...) and i have seen figures as low as 15% (good gearing, good oil etc).
Previous Topic:Original Wheels On A KE30
Next Topic:dying carpets
Current Time: Fri Nov 20 14:56:08 UTC 2026
Total time taken to generate the page: 0.12936902046204 seconds
