Toymods » Tech & Conversions » ra40 diff and front struts into a ta23
people100
Rocklea qld
ra40 diff and front struts into a ta23 Wed, 07 January 2004 09:18 Go to next message
I have a ta23 and was wondering how much better the struts and brakes out of a ra40 would be as to my ta23 ones. How much is involved in fitting the diff and front end out of the ra40 into the ta23. will i get much gains over the standard ta23 stuff.
Snyper
Re: ra40 diff and front struts into a ta23 Wed, 07 January 2004 09:30 Go to previous messageGo to next message
not sure about the diff but I know the struts bolt right in, they also give bigger brakes too, but then you need to have a minimum of 14" wheels on the front.
Brendon
ra23celica
Re: ra40 diff and front struts into a ta23 Thu, 08 January 2004 00:06 Go to previous message
If its just the diff centre it will fit, both being a T series, but if its the entire rear axle, drum to drum, not likely no, as the suspension mounting brackets do not line up and the axle is longer than the original set-up in the '23.
Mitch.
Previous Topic:Creaky Clutch
Next Topic:what fuel to use in a 18R-C
Current Time: Thu Oct 22 14:53:13 UTC 2026
Total time taken to generate the page: 0.0048158168792725 seconds
