Toymods » Tech & Conversions » 1/4 mile times for RA23 with 18RG?
azzsaccRA23
Hobart, TAS
1/4 mile times for RA23 with 18RG? Thu, 01 August 2002 11:20 Go to next message
What would a ra23 with a standard 18rg do on the quarter mile.
An 18rg with a good 2 and 1/4 inch exhaust would make nearly 150hp in a ra23 that weighs about 1100kg, i would estimate about a low 15 second time?
[Updated on: Thu, 01 August 2002 11:21]
GAZZAke25
Re: 1/4 mile times for RA23 with 18RG? Thu, 01 August 2002 14:22 Go to previous messageGo to next message
Gday
I would think it would be more along the lines of high 16s
as I do know people with these engines in the same car with quite a bit of work done to them and they can only pull mid to high 16s, wich I think is still a quick time and plenty of fun on the streets.
Good luck with it.
Garreth
TurboRG
Nor Calif USA
Re: 1/4 mile times for RA23 with 18RG? Thu, 01 August 2002 18:54 Go to previous messageGo to next message
When I had a stock RG in my 72 it
would run high 16s.
but it had a 2 1/2 exh.
Now I have another build RG
Stock 40m carbs
304/288 cams
92 mm bore 10.5 forged piston
and it has run 15.3s at 88mph.
TOY77
Re: 1/4 mile times for RA23 with 18RG? Fri, 02 August 2002 06:24 Go to previous messageGo to next message
g'day
mine had
40mm webers
hi comp. pistons
cams
lightened flywheel
extractors and a 2 1/4 exhaust
used to do mid to high 15's in my 28 with the sub box
in it (big heavy thing.... guessing 80kg....)
Stew
TurboRG
Nor Calif USA
Re: 1/4 mile times for RA23 with 18RG? Fri, 02 August 2002 18:50 Go to previous messageGo to next message
My car should run high to mid 14's. If
I put some slicks, LSD, 45mm webers,
and a aftermarket ignition.
Shteeve
near chris and murray vic
Re: 1/4 mile times for RA23 with 18RG? Tue, 06 August 2002 02:34 Go to previous message
ummm i was just mucking around in my celica, and with a fat assed mate in the front and spare set of wheels in the back we were timing 1/4 miles at low seventeens, only mods are 2 inch exhaust and cams, but it was out of tune and apparently i need to get the shims ground so the cams work (?)
yeah its a bit of a mess at the moment, but good fun anyway. always fun seeing the look on na silvia driver's faces when i beat them muahaha Evil or Very Mad
Previous Topic:Awesome Skyline book!
Next Topic:Need new motor for SV21 thinking of 3sgte?
Current Time: Thu Nov 19 19:21:48 UTC 2026
Total time taken to generate the page: 0.0069470405578613 seconds
