Toymods » Tech & Conversions » boost problems
2Lsupra
boost problems Wed, 07 January 2004 15:39 Go to next message
hi jsut wondering if any one can help me with this one.
i just installed a hks FCD on my gen 1 1ggte. so now when boost goes past the previous cut out point of about 11psi through to 14 the car stutters and chugs just like when you hit a speed limiter...
ne understand?
thanx
stew
2Lsupra
Re: boost problems Thu, 08 January 2004 16:11 Go to previous messageGo to next message
carn guys any help at all?
ddeane
PNG
Re: boost problems Thu, 08 January 2004 23:31 Go to previous messageGo to next message
Gidday
I may not be right, but if the FCD has been correctly installed it sounds very much like ignition breakdown. My car had exactly the same problem which was solved with the replacement of the ignition leads. The change was dramatic, as the effect had been as if I was hitting a fuel cut/rev limiter. I had tried everything and the replacement of the leads was the last resort. You can source leads from TopGun for about $87. If this is the problem can you please let me know.
Craig
Craig
Remedy
Southern Sydney
Re: boost problems Thu, 08 January 2004 23:42 Go to previous messageGo to next message
yep either an ignition or possible a fuel problem.
check plugs, maybe fouled etc. Check fuel filters too.
Allan
Re: boost problems Fri, 09 January 2004 01:17 Go to previous messageGo to next message
that or its pinging its ass off / turbos surging screaming SAVE ME SAVE ME as your pushing it well past its design limits at 14 psi
Allan
2Lsupra
Re: boost problems Fri, 09 January 2004 02:47 Go to previous message
hmmm i see, well perhaps it may be a combination of both of those. i think i might try the new leads first though, its worth a try.
cheers for the help guys.
i'll let ya know how it goes ddeane...
Previous Topic:Flywheel sizes 7M and 2J
Next Topic:3tgte - changing oil - oil capacity
Current Time: Fri Nov 20 10:47:55 UTC 2026
Total time taken to generate the page: 0.0061080455780029 seconds
