Toymods » Tech & Conversions » 4AGE 20V and 6 speed g/box
Michael P
4AGE 20V and 6 speed g/box Wed, 07 January 2004 21:29 Go to next message
What 6 speed manual box comes fitted to Ae111 20V setup. I have been told that this box is LSD. Is this true??? Any idea where I can get information on this box. I believe this 20V + 6 speed setup has rev limit on 1st and 6th gear to protect syncros in box. Is this true??? Am I going to have problems fitting AE92 mechanical speedo drive into this box??? What is the shift pattern on this box and will I have to change the AE92 shifter and cable setup (5 speed) to the one supplied with the front cut???
Johnny
Sydney, OZ
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 01:07 Go to previous messageGo to next message
C60(or was it a G6?), first found in the AE101 BZ touring.
No not all of are LSD, depends what model it came out of and what options were asked for when bought new.
I think some one spun something there...
Yes, they aren't interchangeable from memory.... also top mount won't fit without mod's
R 1 3 5
2 4 6
Using the standard setup, you can get All the forward gears, but not reverse. You can modify it so you can get it, but its a pain in the butt! Use all the cables and shifter from the cut, and you'll have no problems.
Michael P
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 01:16 Go to previous messageGo to next message
Any way of identifying a LSD box from a std box. Also what modifications are required to the topmount of box and any suggestions on what to do to get the speedo operating.
MR. 2
Parramatta
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 01:27 Go to previous messageGo to next message
turn one of the wheel on the car (when the cars tyres off the ground) and then both should turn the same way, however if its anything like the mr2 turbo lsd, box very hard to tell as its dosnt appear to be when u spin one of the wheels...
Michael P
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 01:38 Go to previous messageGo to next message
I meant was there any way to tell the difference between LSD and std by looking at them as the box is still in the frontcut.
Johnny
Sydney, OZ
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 02:17 Go to previous messageGo to next message
Nope
Quote:
Also what modifications are required to the topmount of box.
Have to strengthen the plate that comes on the box, cut off the top of it, build it up to the correct height with some thick plate. Then using your existing one that bolts to the car (round upper with a plate weld to it), you have to cut both ends off, cut a slit and weld this to the bottom section that has been prepared as described above. If in Sydney, I can do the mod $200, but the engine needs to be in the car so I can measure the distances.
Johnny
Sydney, OZ
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 02:22 Go to previous messageGo to next message
I can also have a look at the speedo and tell you what it is interchangeable with, otherwise you'll have to find the corresponding wire in the back of you speedo and wire the 3 electrical outputs directly from the box to the speedo
Matt20v
Richmond NSW
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 03:40 Go to previous messageGo to next message
if you were useing a 5 speed box as i did u just use the same cable speed sensor from ur car on that box and use the wire from the back of the dash which has the speed in it in my rv it was purple and hook it to the ecu but with the 6 speed as there diffrent ratios i dont no who u can get that to work..
matt
jasonp1977
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 06:34 Go to previous messageGo to next message
1. There are two part # for the Blacktop 20v 6speed transaxle (C160).
a. 30300 1A 250 - without LSD
b. 30300 1A 260 - LSD
These # are on the Transxles bell housing near the stater - ink printed sticker that will fade.
2. From the vehicle ID plate the LSD box is designated as C160 - 12C.
12C = LSD
NuGeN
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 12:27 Go to previous messageGo to next message
ok... is the 6 speed out of the ae111 called c60? or c160?
I was always thought it was the c60, since the c60 was based on the c50 series.
jasonp1977
Re: 4AGE 20V and 6 speed g/box Thu, 08 January 2004 21:33 Go to previous message
the transaxel code listed above is from a Levin BZ-R, I have a photo of the plate somewhere. The AE111 6-speed code is C160.
Previous Topic:AFM for 3S-GTE
Next Topic:GZE Conversion Stalling
Current Time: Fri Nov 20 07:09:58 UTC 2026
Total time taken to generate the page: 0.11878418922424 seconds
