Toymods » Tech & Conversions » flywheel bolts for 4AC/4AG
TE72_Turbo
flywheel bolts for 4AC/4AG Thu, 01 August 2002 13:01 Go to next message
do all 4A engines have 8 flywheel bolts, or do the RWD 4AC's have only 6?
jazae86
Re: flywheel bolts for 4AC/4AG Thu, 01 August 2002 13:29 Go to previous messageGo to next message
4AC are 6,
4AG SHOULD be 8 but there are some that are 6. MOST are 8. You want 8 as it will be stronger.
Use new flywheel bolts. I don't know about you, but I like my feet, they help me walk.
Jaz
Grega
melbourne.victoria.austra...
Re: flywheel bolts for 4AC/4AG Thu, 01 August 2002 19:50 Go to previous messageGo to next message
early 86kw had 6 bolts. later 100kw have 8.
flywheel bolts are cheap insurance - get new ones.
TE72_Turbo
Re: flywheel bolts for 4AC/4AG Fri, 02 August 2002 10:43 Go to previous messageGo to next message
thanks guys
what is the diameter of the clutch plate for a 100kw flywheel? Do you know if someone makes clutches for the 100kw motor to fit the T50 gearbox?
Grega
Re: flywheel bolts for 4AC/4AG Fri, 02 August 2002 11:30 Go to previous messageGo to next message
am told a standard FWD 100kw clutch kit will suit, just make sure you get a spigot bush to go in the back of the crank - a standard 4AC spigot should suit.
dorikin
NE Melbourne
Re: flywheel bolts for 4AC/4AG Fri, 02 August 2002 13:55 Go to previous messageGo to next message
100kW 4AGE has 215mm clutch
88kW 4AGE has 8 bolt flywheel too. some very early ones may have been 6, but mine deff has 8!!!
Grega
Re: flywheel bolts for 4AC/4AG Sat, 03 August 2002 10:31 Go to previous messageGo to next message
yer dori, like the 7 rib 86kw motors - ie: like in the MR2's dude i pulled down a 7 rib and come to think of it that has 8 holes too
jazae86
Re: flywheel bolts for 4AC/4AG Sat, 03 August 2002 12:22 Go to previous message
Both of my RWD 4AG's have 8 bolt.
TVIS is 200mm
100Kw (small port) is 212mm.
212 fit's fine in t50 but GZE clutch is a big no (unless you grind bellhousing).
My friend runs GZE on 200mm TRD puck and pressure plate, no slip. Tho you want to use 212 to ensure that it doesn't slip. 212 v's 200 is something like 155cm^2 more area to grip:
ie (pi*21.2^2-pi*20^2 =~155)
Jaz
Previous Topic:3tgte fuel pressure
Next Topic:1jz vs 7M-GTE
Current Time: Sat Oct 24 03:58:54 UTC 2026
Total time taken to generate the page: 0.0049459934234619 seconds
