Toymods » Tech & Conversions » Altezza 3SGE into Sprinter nearly finished.
Bill Sherwood
Brisbane / Gold Coast
Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 14:17 Go to next message
Here's a couple of pics, taken yesterday.
The engine bay is basically all done now, with just a couple of minor things to finish up.
http://www.billzilla.org/ae863sgebay3.jpg
We were going to fit buttons to the existing AE-82 steering wheel I had in the car, but as it turned out the Altezza SXE-10 / RS200 one bolts straight on, so that's what it now has. (minus the airbag!)
http://www.billzilla.org/ae86newpanel.jpg
I gave the car a fifteen minute odd drive today and it's not too bad, though still needs a little fiddling to get it all right. The water temp behaves very well, but the engine has a few rough spots that we think we know the cause of. There's a slight lump to the idle, we're not sure if it's supposed to have that or not.
One of the problems is the fuel pressure, as we're just not sure what it's supposed to be. (The Altezza's have the FPR in the tank, not on the fuel rail)
It seems to run okay with 60psi, but we're still trying different settings.
The HID headlight work just fine, though I haven't tried them at night yet.
The radiator is a custom made unit from a local company, as is most of the rest of the water cooling gear from their off the shelf gadgets.
The EFI computer sits in that black box on the FL of the engine bay, and it's all been modified so that most of the relays sit in there out of the way.
The battery is one of those compact Odessy types, and it sits right under the inlet manifold.
The brakes are very bad at the moment, it just won't stop very well at all so we have to try some smaller master cylinders.
The dashboard is nearly done, and we can't get the Altezza fuel gauge working so we're sticking in the AE-86 one to the side of the Altezza panel. (The fuel sender goes to the bodywork computer, which then sends a multiplex signal to the panel. All too hard!!)
The speedo is also a little tricky, as the Altezza's use the ABS sensor from one front wheel to feed a signal to the ABS computer, which then sends a signal to the panel. We're working on how to get one of the ABS sensors working with one of the front wheels ....
So for the moment, my car has gone from about 340,000km odd down to 12,607km, and is there to stay for a while. Smile
And oh yeah, I have to get on the lathe and make up a shifter knob. Wink
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 14:25 Go to previous messageGo to next message
That looks awesome Bill! Smile
CLG
Perth, Western Australia
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 14:43 Go to previous messageGo to next message
Off topic Bill, what struts and lower control arms are you using, and what camber and castor are you running, please?
Bill Sherwood
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 15:09 Go to previous messageGo to next message
CLG wrote on Fri, 09 January 2004 01:43
It's got Cusco front suspension all through it, with Cashiew struts - All from Japan from when I used to fly there often.
I run about 3deg neg castor and about 1deg neg camber.
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 15:10 Go to previous messageGo to next message
I love that dash.... *drools* working or not it looks the shit! Nod
ae95
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 16:16 Go to previous messageGo to next message
looks awesome, very neat install.
Question. is it auto,manual,tiptronic?
crostek
Oyster bay NSW
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 16:32 Go to previous messageGo to next message
Shocked looks fantastic wish I had the money to buy a front cut and do that to the old sprinter Crying or Very Sad Crying or Very Sad
Bill have you thought about getting a Programmable Integrated controller (PIC) chip done to control the dash, simple program with Analogue to Digital convert chip for fuel sender and pulse counter from the ABS sensor.
Confused
oldskoolrolla
Ashmore, QLD
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 16:48 Go to previous messageGo to next message
Hi Bill,
Your Sprinter is looking totally awesome, so far!
The Altezza chronograph speedo looks totally sweet, and matched with the updated shifter, looks really retro-tech Very Happy
I hope you iron out the 3s-gte bugs, coz I think it will be one of the best sprinters on the road when its done Very Happy
[Updated on: Thu, 08 January 2004 16:51]
Grega
melbourne.victoria.austra...
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 19:16 Go to previous messageGo to next message
nice work mate!
Danish
icon14.gif  Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 19:22 Go to previous messageGo to next message
That's dope savvy! Shocked
KOFFEE-BLACK
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 21:51 Go to previous messageGo to next message
Cool! Looking Good Bill!
You using the Altezza box too?
jase
Re: Altezza 3SGE into Sprinter nearly finished. Thu, 08 January 2004 23:21 Go to previous messageGo to next message
Great to see some thinking outside the square Bill. Well Done!
With the Fuel gauge, when I did a dash conversion once we retrofitted the "back" of the gauge to a newer dash? Is that possible, to modify the rear of the 86 gauge and fit it into the altez. dash facia?
Iwannatoyota
Dubbo
Re: Altezza 3SGE into Sprinter nearly finished. Fri, 09 January 2004 11:32 Go to previous messageGo to next message
that's awsome!!! Love the dash!
Iwannatoyota
Dubbo
Re: Altezza 3SGE into Sprinter nearly finished. Fri, 09 January 2004 11:36 Go to previous messageGo to next message
wagonist
Toymods Club Treasurer
Re: Altezza 3SGE into Sprinter nearly finished. Fri, 09 January 2004 12:19 Go to previous messageGo to next message
Possible solution to your speedo dilemma.
Go to an aftermarket cruise control specialist.
They usually have bits & pieces to fit sensors to cars (usually on tailshafts/driveshafts) that run a mechanical speedo rather than an electronic one.
They have adaptors that fit into the gearbox where your speedo cable goes in.
Or Fit something to your tailshaft.
Then feed that signal to whatever you need.
I think the MX83 Cressidas had a factory sensor on their tailshaft for the ABS
[Updated on: Fri, 09 January 2004 12:20]
mcrish
nu zilland
Re: Altezza 3SGE into Sprinter nearly finished. Fri, 09 January 2004 12:51 Go to previous messageGo to next message
goddam, that is the best thing i have ever seen, hope u get it sorted fully soon my friend, and then send it over to nz for me Razz
haha, just kidding, but honestly, that is one of the coolest things i have ever seen
Bill Sherwood
Re: Altezza 3SGE into Sprinter nearly finished. Fri, 09 January 2004 13:36 Go to previous messageGo to next message
KOFFEE-BLACK - Yes, it's the stock Altezza 5-speed automatic gearbox.
Jase - The original AE-86 fuel gauge is now sitting up in the top-right corner of the spare space of the instrument panel. Just gotta get a light onto it now.
AE95 - It works like a regular slushbox or a Tiptronic, depends where you have the selector.
Crostek - Not sure, it may not be that simple with the way the panel & ECU(s) work. It's all pretty weird and the electronics guy is very darn clever ...
wagonist - We know how to make it work, we just have to work out where to put the sensor.
ae86drift
sydney.au
Re: Altezza 3SGE into Sprinter nearly finished. Sun, 11 January 2004 11:18 Go to previous messageGo to next message
i love this engine
if i had 10k i would do this exact engine mod and get the trd gauges and a h-plate shifter and an aftermarket ECU and some BIG brakes and a set of BIG BALLS to drive it
nice work bill, any reference material of other cars with the conversion?
Re: Altezza 3SGE into Sprinter nearly finished. Sun, 11 January 2004 13:17 Go to previous messageGo to next message
Ahhhh, awesome. I was going to do this conversion, until a *certain nameless* wrecker *lost* my engine. I often wondered how it would have been if I'd gone that way, and it's great to see some happy snaps of your attempt. Top effort!
Bill Sherwood
Re: Altezza 3SGE into Sprinter nearly finished. Sun, 11 January 2004 13:47 Go to previous messageGo to next message
ae86drift - There's at least a few other cars around the world that also have the blacktop 3SGE's, though I haven't heard of anyone anywhere that kept the automatic box behind them.
FWIW we didn't get the master cylinder size right the first time, so that big brake conversion that was going to wait is now going to start on Tuesday. So at the worst case we only have to do a cylinder change once for the fronts.
Re: Altezza 3SGE into Sprinter nearly finished. Mon, 12 January 2004 12:02 Go to previous messageGo to next message
Hey Bill a while ago you mentioned that you wanted to use some spacers between your crossmember and chassis. Did you end up doing this and if so what RCA's did you end up using?
7M-Brisbane
Re: Altezza 3SGE into Sprinter nearly finished. Mon, 12 January 2004 13:35 Go to previous messageGo to next message
Looks good, sounds terrible Very Happy
7M-Brisbane
Re: Altezza 3SGE into Sprinter nearly finished. Mon, 12 January 2004 13:42 Go to previous messageGo to next message
It would have been terrible, having had a close look it seems like a bastard of a job to me.
StuC
Re: Altezza 3SGE into Sprinter nearly finished. Mon, 12 January 2004 22:58 Go to previous messageGo to next message
Blacktop 3sge?I take it its out of a lexus (Is300)goin by the altezza name. What are they all about.Whats the stock power output, AFM or MAP. Can someone let me know what they're all about? Nice conversion too mate
Bill Sherwood
Re: Altezza 3SGE into Sprinter nearly finished. Tue, 13 January 2004 00:52 Go to previous message
Cool1 - Yes, it's got 10mm spacers between the crossmember & chassis rails. The RCA's are the ones that have been in it for years, about 300mm thick i think.
StuC - No, it's out of an RS200 Altezza. About 195hp I think, and they use a hot-wire AFM, which you can just see in the inlet pipe next to the RH headlight.
Previous Topic:Supra TT MK4 turbo problem - help!
Next Topic:Twincam AE82 CV Joints
Current Time: Sat Nov 21 01:08:47 UTC 2026
Total time taken to generate the page: 0.0080611705780029 seconds
