Toymods » Tech & Conversions » Conversion Questions???
WOW16V
Glossodia,NSW
Conversion Questions??? Thu, 08 January 2004 23:17 Go to next message
I've been thinking about this for awhile now,and i think it's time to put my questions to rest rest and find out from the techies whether this will work or not.
I wannna turbo my existing 3sge engine in my mr2,basically just for a lil extra power that's all.so i will only be running 6-8psi max.
So if i get the mr2 turbo's exhaust/turbo manifold,the turbo,the 2bar map sensor and the original mr2 turbo factory ecu,this should be all i need,and a small intercooler as well.
My main question is,i've heard the ecu's are swappable cauz the ecu plugs are the same the only problem being the fuel pump,which requires some fancy wiring to get it operating correctly.So if the ecu's could be swapped and wired to work properly then this should work,shouldn't it?????
Cheers Adrian
Chris Davey
sunny coast, qld
Re: Conversion Questions??? Fri, 09 January 2004 01:20 Go to previous messageGo to next message
what is the compression ratio on the 3sge? As it will be higher than the 3s-gte, i wouldn't think you would want the same tune as the 3s-gte. So you could decompress it or get a programmable computer and get it tuned well.
Personally, I would just do a 3s-gte swap or sell your car and buy a turbo one, but i guess that isn't what you want to hear :0
sideshow
Re: Conversion Questions??? Fri, 09 January 2004 01:24 Go to previous messageGo to next message
bass is right
dont watse time pullin things off and on to make yr engine turbo
its easier and prob only abit more expewnsive in the end
the fuel pump wiring is easy to fix
onejayzed
Re: Conversion Questions??? Fri, 09 January 2004 01:53 Go to previous messageGo to next message
people put low boost turbos and manifolding off 200SXs/GTiRs onto NA SR20s running the NA computer with shining results apparently. never done it myself or know anyone, just seen it a few times on the net.
maybe it's a similar deal for the 3SGE? i mean, if you're only running 5-6psi it would prob lean out the overly rich factory mixtures at WOT.
i'd say give it a shot, just keep your old manifolding and stuff if it doesn't work so you can bring it back to original and sell it for a turbo one.
sideshow
Re: Conversion Questions??? Fri, 09 January 2004 02:29 Go to previous messageGo to next message
yer but isnt it a bastard to keep changin manifolds on a 3sge especially in an mr2
if u want to keep car for long time then do it prperly
onejayzed
Re: Conversion Questions??? Fri, 09 January 2004 04:26 Go to previous messageGo to next message
yeah true, but it depends what WOW16V is after and if it's on the road or not.... Confused
WOW16V
Glossodia,NSW
Re: Conversion Questions??? Fri, 09 January 2004 07:23 Go to previous message
Ok thanks guys,but WILL it work.This will be a fair bit cheaper then going a half-cut and then paying through the roof for the labor.
Ecu-should be around $250-$300
Manifold/turbo 400-500
Map sensor ???
Interrcooler i already have and i can get the plumbing done piss cheap.
As with the wiring,i'll just go through the wiring diagrams,identify the differences with the pinouts and wire them up accordingly.
Previous Topic:97 camry taco wire diagram or colour
Next Topic:3S series blocks
Current Time: Mon Oct 5 00:13:04 UTC 2026
Total time taken to generate the page: 0.0049641132354736 seconds
