Toymods » Tech & Conversions » GZE Manual Translation Assistance Required
jasonp1977
GZE Manual Translation Assistance Required Fri, 09 January 2004 01:04 Go to next message
Hi everyone,
I have a friend that needs to adjust the screw on their GZE AFM to factory specs while we are troubleshooting it. I have the pages with the instructions from the engine manual, but I cant make out what I'm meant to do with the Vf pin from the diagnostic block at 2500rpm... if anyone out there could translate the following pages it would be greatly appreciated.
http://www.rollamods.com/holding/gzeafm1.jpg
http://www.rollamods.com/holding/gzeafm2.jpg
http://www.rollamods.com/holding/gzeafm3.jpg
I can also scan any other section of the complete toyota workshop manual if anyone requires it and can translate the relevant bits.
Jason
sideshow
Re: GZE Manual Translation Assistance Required Fri, 09 January 2004 01:26 Go to previous messageGo to next message
what is the engine doin
the airflow wont make much difference
when u turn the screw all u hear is idle go up and down
turn it till idle comes up and is steady
if its not doin this the problem is elsewhere
unless u have adjusted the spring inside the airflow
jasonp1977
Re: GZE Manual Translation Assistance Required Fri, 09 January 2004 01:41 Go to previous messageGo to next message
It's not my car, but the owner want's to set it properly and the procedure is there if someone can read it...
So far the owner has changed:
1. AFM
2. CAS
3. TPS
4. O2 sensor
5. VSV's
6. FPR
7. Supercharger
8. timing
9. ABV
10. Fuel and Air Filters
And a bunch of other stuff too which I cant recall...
The conversion was done in 1997, and ran perfectly until about the last year or so.
The ECU was logging a code for the TPS so I adjusted that properly, and his CAS was on the way out. There was also a leak on the supercharger outlet which has all been fixed now, but the car still runs like an absolute dog all through the rev range. The charger is making 7psi of manifold pressure but it feel's weaker than a 100kw.
So basically I've just come into the equation and we're starting from basics.
feral4mr2
Bundaberg, Qld.
Re: GZE Manual Translation Assistance Required Fri, 09 January 2004 03:40 Go to previous messageGo to next message
Freak the adjustment screw on the AFM is basically a air bypass, it will mostly only adjust fuel ratio at idle.
when i get back home again later i'll look in my 'english' version manual and see if they say about adjusting it.
Smile
Chris Davey
sunny coast, qld
Re: GZE Manual Translation Assistance Required Fri, 09 January 2004 03:54 Go to previous message
i can read all the hiragana and katakana but i can't put it all together to make sense Smile
i guess i am no help. But thanks for the Japanese practise Very Happy
Previous Topic:RA60 Info
Next Topic:Brake light on. (AE86)
Current Time: Fri Nov 20 11:58:20 UTC 2026
Total time taken to generate the page: 0.0047059059143066 seconds
