Toymods » Tech & Conversions » "T" terminal on 4age 86kw
ae95
"T" terminal on 4age 86kw Fri, 09 January 2004 07:41 Go to next message
Where should the "T" terminal(green/black) on the 4age bigport go?
feral4mr2
Bundaberg, Qld.
Re: "T" terminal on 4age 86kw Fri, 09 January 2004 07:55 Go to previous messageGo to next message
Freak you mean the T from the ECU to the diagnostics plug?
different colour to the 88kw but should follow the exact same path.
ae95
Re: "T" terminal on 4age 86kw Fri, 09 January 2004 08:17 Go to previous messageGo to next message
yep thats the one, but where does it go from the diagnostic plug?
at the diagnostic plug it joins with a pink wire and goes where?
feral4mr2
Bundaberg, Qld.
Re: "T" terminal on 4age 86kw Fri, 09 January 2004 08:50 Go to previous messageGo to next message
Freak well in my wiring diagram T goes from the diagnostics box directly to the ECU. E1 though is tee'd into another wire before it goes to the ECU, E1 is just an earth though.
as i said before this is for a 88kw aw11 bigport motor, so i dont know if it's 100% the same for yours.
my diagram shows T as a white wire and E1 as brown.
ae95
Re: "T" terminal on 4age 86kw Fri, 09 January 2004 20:06 Go to previous messageGo to next message
where does the white wire go to after it hits the diagplug coming from the ecu, im pretty sure it changes colour and heads to a part of the engine.
Re: "T" terminal on 4age 86kw Sat, 10 January 2004 00:42 Go to previous messageGo to next message
from the ECU, the wire goes to the diagnostics connector. Nowhere else....
BUT - also on your diagnostics connector should be an earth terminal.... the idea being that to utilise the diagnotics function (either for engine codes, timing etc) you simply short the diagnotics pin to earth using the "special service tool 45" (ie a paperclip)
What is your reason for asking this question?
ae95
Re: "T" terminal on 4age 86kw Sat, 10 January 2004 07:26 Go to previous messageGo to next message
trying to accurately adjust the timing. i've tried shorting it at the ecu by plugging a wire into the T terminal to the brown wire and also the the (-) of the battery. i didnt notice anything, no rpm drop...etc
my car was converted from 4ac and when the conversion was done the person did not wire up a diagnostic plug
ae95
Re: "T" terminal on 4age 86kw Sat, 10 January 2004 07:48 Go to previous message
also where is the check engine light on a auspec dash? or doesnt it have one
mine is either not working or not wired up
Previous Topic:Upgrades on the 4k...plz help!!!!
Next Topic:ma70 turbo and jza-70 air-filters. Are they the same?
Current Time: Sat Nov 21 02:07:46 UTC 2026
Total time taken to generate the page: 0.0052120685577393 seconds
