Toymods » Tech & Conversions » Incorrect RPM Readings
newcarowner
Incorrect RPM Readings Fri, 09 January 2004 16:08 Go to next message
Hi Wasup.
A friend of mine just did a very clean 89 afm twincoil 4agze swap in a 91 ee-90 corolla. Now the only apparent problem is the the rpm readings are incorrect, seems as if its reading in half, and because of the the engine check light is constantly on cause the car to stall allot... We tried a new Knock Sensor same problems ??
Any Ideas.
Your quick and Immidiate responces will be highy Anticipated.
Thanks in Advance
sideshow
Re: Incorrect RPM Readings Sat, 10 January 2004 00:09 Go to previous messageGo to next message
u need a booster for yr tacho signal that comes from the ignitor to the tacho
u must be runnin tacho signal from one coil
what error code r u gettin if the check light is always on
newcarowner
Re: Incorrect RPM Readings Sun, 11 January 2004 22:35 Go to previous messageGo to next message
Will go down to the shop and try and get the codes......... As for boosting the signal from the igniter, can you give me a more detailed way of doing this.
Necros
Re: Incorrect RPM Readings Mon, 12 January 2004 10:32 Go to previous messageGo to next message
There is a melbourne based company that make and sell tacho boosters for applications just like yours.... They have posted on this site recently (~last 3 months)
Use the search feature and look for "tacho booster" ;p
[Updated on: Mon, 12 January 2004 10:33]
newcarowner
Re: Incorrect RPM Readings Mon, 12 January 2004 15:37 Go to previous message
Thank u , that will help allot
Previous Topic:The Un-Desired Effects of running a Lightened Flywheel on a stock setup?
Next Topic:r series engine in a ta22
Current Time: Sat Nov 21 00:13:32 UTC 2026
Total time taken to generate the page: 0.0048420429229736 seconds
