Toymods » Tech & Conversions » AW11 tacho install
old_mr2
AW11 tacho install Fri, 09 January 2004 18:56 Go to next message
Guys
I have a tacho that I would like to install in my AW11.
Can anyone explain which wires go to where? It is an Autometer. I dont have any instructions.
Also, what type of wire/s should I use to complete the connetion. As they have been chopped to 6 inches long out the back of the tacho.
feral?
Martin
feral4mr2
Bundaberg, Qld.
Re: AW11 tacho install Fri, 09 January 2004 22:39 Go to previous messageGo to next message
Freak Martin, there is a black wire that goes from the ignitor to the tacho. that will be your signal wire to the tacho, you should be able to tap into it up front there somewhere if you can find it...
might have to pull the instrument cluster out, fun fun.. Shocked
it's been a while since i put a tacho on anything, i dont know the wire colours of the Autometer sorry.
i have never put an aftermarket tacho on the feral, the original one does me fine. Smile
the same guage(size) wires that are coming outta it should be fine to use.
sideshow
Re: AW11 tacho install Sat, 10 January 2004 00:07 Go to previous messageGo to next message
in yr diagnostic connector in engine bay theres an ig terminal
thats yr rpm signal
run wire from it to green wire on tacho
other wire on tacho are
red is 12v ignition
black is earth
white is lights
old_mr2
Re: AW11 tacho install Sat, 10 January 2004 13:13 Go to previous message
ok thanks guys
I will see how i go
Previous Topic:18R-G Exhaust Gasket
Next Topic:Camry questions OR please help an uneducated noob
Current Time: Sat Nov 21 00:29:42 UTC 2026
Total time taken to generate the page: 0.0037112236022949 seconds
