Toymods » Tech & Conversions » AE71 gearbox crossmember
bmak
AE71 gearbox crossmember Sat, 10 January 2004 23:44 Go to next message
How many bolts hold these to the car?
Ive only seen an auto 1 that had 4
My ke70 didnt have holes in the same position so i wasnt sure if it fits.
Ive just adapted the KE70 1 for now
chrisss
melb
Re: AE71 gearbox crossmember Sun, 11 January 2004 00:23 Go to previous messageGo to next message
brad whats the prob with the one I sold you with the car?
the regular AE71 sedan one does not fit as I already bought one and tried that.
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 01:18 Go to previous messageGo to next message
hey chris
nothing wrong with the 1 you gave me but i need 1 for my sedan.
the panelvan is currently stripped & getting prepared for painting.
chrisss
melb
Re: AE71 gearbox crossmember Sun, 11 January 2004 01:27 Go to previous messageGo to next message
I thnk that it just 2 bolts....its not a perfect fit,you have to put 1 bolt in first and sort of push the mount a bit to get the other hole to line up...hope that makes sense!
anyway, how u goin with it so far?
[Updated on: Sun, 11 January 2004 01:27]
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 02:07 Go to previous messageGo to next message
Ok
got the panelvan completely stripped & picked up a all blue interior stuff for it.
going to take the engine bay back to bare metal next.
I'm also yet to finish the A conversion on my sedan so time is a bit limited as i go back to work next week:(
chrisss
melb
Re: AE71 gearbox crossmember Sun, 11 January 2004 02:12 Go to previous messageGo to next message
whoa, your going all eh.
you got a ke70 or ae71 sedan as well or is the a series conv for the ke20?
also I assumed that the crossmember you were asking about was for the panelvan.
the sedan has different location holes for the x member and so they have different x members which are not interchangable.
I got the xmember for the panelvan off a te71
[Updated on: Sun, 11 January 2004 02:15]
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 02:24 Go to previous messageGo to next message
I'm converting a ke70 sedan to 4age. actually had an AE92 lined up but it was taken just before i got there:(
shouldnt need anything for the panelvan as i already had it up & running before i pulled it apart.
Just having trouble finding a crossmember for my sedan & i havent even seen an AE71 manual one because all the cars ive looked at have had them removed with the gearbox:(
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 02:34 Go to previous messageGo to next message
Actually got a question on the panelvan
when i tried to start it there was no power from the start switch to starter motor. Had you removed anything? Did it have a start relay? My sedan has to have a relay for this.
I need to get hold of a wiring diagram that shows all this sort of stuff but having trouble getting hold of 1
IRA11Y
Club Member
Re: AE71 gearbox crossmember Sun, 11 January 2004 02:39 Go to previous messageGo to next message
4 bolts.. it fits the ke70
chrisss
melb
Re: AE71 gearbox crossmember Sun, 11 January 2004 03:52 Go to previous messageGo to next message
the wiring for the starter was sold off with the 4ag.
in amonst the bits and pieces that I gave you extra you will find the wiring needed for the starter. I grabbed them of an ae71 and it just plugs into your loom.
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 04:38 Go to previous messageGo to next message
Thanx for that, thought something was missing. i'll sort it all out once i get to that stage & get hold of a wiring diagram.
My KE70 has 4 bolt holes for the crossmember but they are far apart, the AE71 auto i looked at actually had 3 each side & the crossmember used the rear 4. i guess i bolt it up just using the rear 2.
Out of the 15 or so AE71's i looked at not 1 had a manual crossmember anyway so i'm stuck using my dodgy 1 for now.
IRA11Y
Club Member
Re: AE71 gearbox crossmember Sun, 11 January 2004 04:51 Go to previous messageGo to next message
i actually use a AE86 one turned around backwards using two bolts Smile
bmak
Re: AE71 gearbox crossmember Sun, 11 January 2004 08:34 Go to previous messageGo to next message
when i go back to work i think i'll just make a decent 1 from scratch.
I was hoping for a factory looking 1 but it seems too much trouble.
The ke70 1 is a bit dodgy.
Re: AE71 gearbox crossmember Sun, 11 January 2004 14:23 Go to previous message
actually i only remember there being 2 bolts on my AE71 crossmember.....
but of course i am 20000kms from my car so i cant look.
Previous Topic:3S-GTE cam gear/belt cover(s)
Next Topic:MA71 7MGTE BOV Installation Grrrrrrr :)
Current Time: Fri Oct 30 18:19:05 UTC 2026
Total time taken to generate the page: 0.0069358348846436 seconds
