Toymods » Tech & Conversions » 1GGTE in to Hilux need answers about std ECU
swede
1GGTE in to Hilux need answers about std ECU Sun, 11 January 2004 02:09 Go to next message
Im needing some info on transplanting a 1ggte motor into a Hilux.
Ive seen it done but dont know if I should buy a front cut and use the std ECU and wiring ect.
Or am I better of using a blank motor and and a single turbo and a after market ECU something like a Haltech.
Can the Std ECU be used or will there be problems (in case of does the ecu run other part of the car wich the hilux doesn't have like speedo ect) Confused
Re: 1GGTE in to Hilux need answers about std ECU Sun, 11 January 2004 03:16 Go to previous messageGo to next message
there are differences between auto and manual engine ECU's - from my reading, the gearbox ecu can:
tell the engine ECU to modify timing during gearshifts,
probably modify engine behaviour if overdrive (torque lockup) engaged,
tell the engine to run in 'limp home' mode if gearbox sensors (particularly speed) not all hooked up,
there's two speed sensors on the A340e gearbox that i have, ons is used by the gearbox ecu, the other went to the (not used) digital speedo,
cruise control would only add to this complication.
fwiw: if i put my 1G into the RA40, it will be with megasquirt EFI (i butchered the loom upon removal) and either a W58 manual, or a A340e with a sequential shift kit (not using factory gearboxECU).
btw: there's a few previous discussions about 1G ECUs if you search for them. also ddeane and sideshow seem to know heaps about wiring...
Siktoy ra23
Plumpton/sydney
Re: 1GGTE in to Hilux need answers about std ECU Sun, 11 January 2004 05:26 Go to previous messageGo to next message
If you have the money go with an aftermarket ecu I am running an EMS ecu on my ra23 and I have no problems at all and I havent even got it on the dyno yet
I am running the standard fuel map they sent out with it.
BEN
P.S the factory computer looked to hard to wire up so I never tryed Very Happy
slylux
perth WA
    nup
Re: 1GGTE in to Hilux need answers about std ECU Mon, 12 January 2004 13:47 Go to previous messageGo to next message
if u go 1G , go manual .. and after market ecu .. u can use yr hilux gbox and get a custom bellhousing .. 1G r so cheap now .. can get em as eng package no ecu for lik 400 bux .. would be cheap conversion why doesnt toyota come out with something lik that from factory .. 2l 6 way more torq and better fuel than any 22r will ever have ..
Grant
Newcastle, NSW, Australia
Re: 1GGTE in to Hilux need answers about std ECU Tue, 13 January 2004 20:50 Go to previous message
There is no problem using the standard ecu without the auto or speed inputs. A manual ecu is better though as it is mapped slightly differently and will give better performance when matched to the manual box over the auto ecu. You can still run a single turbo with the factory ecu provided you don't reach the limits of the AFM or injectors.
Previous Topic:cold start injector and coolant temps...
Next Topic:Shifter conections on an aw11 4age
Current Time: Fri Oct 23 11:23:27 UTC 2026
Total time taken to generate the page: 0.0050098896026611 seconds
