Toymods » Tech & Conversions » power steering pipes leaking bad, any advice?
dingaling
tas
power steering pipes leaking bad, any advice? Sun, 11 January 2004 10:45 Go to next message
within 20 minutes all my power steering fluid had leaked out.
i found at least 2 places on the power steering pipes that it's leaking from.
doesn't look fixable. I can't patch it up and stop the leak can i? or is there too much pressure? It looks like i'll need new pipes.
are they obtainable? are they expensive? and can i remove the old power steering pipes easily? or is it a big job?
oh yeah the car is a MA70 supra.
V8_MA61
Re: power steering pipes leaking bad, any advice? Sun, 11 January 2004 10:52 Go to previous messageGo to next message
its probably the hi-pressure line...costs about $60 for a non-genuine one, or id say about 80-90 for a genuine one. Do it sooner than later so you dont ruin your pump.
To answer your question...no you cant patch it if its the hp line
Its a relatively large job depending on location of your pipes? WHich one is blown? Picture of it??
[Updated on: Sun, 11 January 2004 10:56]
Remedy
Southern Sydney
you should be able to get replacement hoses straight from toyota parts but they will be expensive. YOu can use generic ones, probably half the price. I had this problem on a st162 celica.
Remedy
Southern Sydney
wow scary
Re: power steering pipes leaking bad, any advice? Sun, 11 January 2004 11:31 Go to previous messageGo to next message
Genuine Toyota part is ludicrously expensive, forget the exact price but it was hundreds. Just go to Enzed or whatever and get one made up, that's what I did on my MA61 a while back and it wasn't too expensive.
dingaling
tas
Re: power steering pipes leaking bad, any advice? Mon, 12 January 2004 04:10 Go to previous messageGo to next message
http://members.dodo.com.au/~urantiacjd/leak.jpg
well those are the 2 leaks i've found so far, could be more tho. there in the rubber hoses, no leaks in the steel pipes.
So enzed should be able to fix me up? will i need to get the whole lot of piping replaced? or can enzed just replace the rubber hoses? i can't see how to unjoin the rubber hoses from the metal pipes.
This is bad timing becuase i need to get my car registered and reliable for my trip to melb (from tas) before the 25th of this month.
anyway thanx for the advice fella's
spectral
Re: power steering pipes leaking bad, any advice? Mon, 12 January 2004 05:53 Go to previous messageGo to next message
i did this in my fiance's 95 Barina. Holden wanted $440 for the hose. Enzed charged me $109 for a custom one.
Fitting was an absolute bitch.. as this one ran from pump, under the radiator, up past the battery, down the back of the engine bay, then down to the rack.
Took me about 4 hours all up.
dingaling
tas
Re: power steering pipes leaking bad, any advice? Mon, 12 January 2004 09:02 Go to previous messageGo to next message
thats not to bad, i mean the amount of money you saved.
was that the steel pipes and all custom made? or just sections?
did you have to remove alot engine stuff to get the new pipes in?
[Updated on: Mon, 12 January 2004 09:03]
spectral
Re: power steering pipes leaking bad, any advice? Mon, 12 January 2004 23:02 Go to previous messageGo to next message
I pulled off all the intake piping (to make getting to the pump easier. Also took out the battery and tray.
I got Enzed to make the hose in 3 sections with brass threaded joiners. Makes it a lot easier to fit.
It was made of a mix of rubber (with the clamped ends) and steel hosing.
I wrapped it in that heat reflecting tape (got it from an exhaust shop for free), so stop the heat perishing it again in the future.
ed_ma61
Lost in the K hole
Re: power steering pipes leaking bad, any advice? Mon, 12 January 2004 23:12 Go to previous messageGo to next message
just take the whole hose off and take it to pirtek, enzed whatever.
they will take the metal end sections (which are custom for your vehicle) and simply rejoin them with a sexy bit of new rubber. you cant do this yourself as they are a crimp fit.
1- take hose off
2- take hose to pirtek
3- hand over money
4- go home and reinstall
speakafreaka
Re: power steering pipes leaking bad, any advice? Tue, 13 January 2004 11:04 Go to previous messageGo to next message
Anyone have the problem of the pump being on the opposite side of the engine after a swap? ive been speaking to pirtek and ive gotta make some measurements.
Whats the best way to route the piping? (1j cressida)
Which side of the pump (on a 1j) is the hipress side, and which side of the rack does this connect to?
does it go: hipress pump -> rack -> reservoir -> lopress pump?
as you can see im attacking this from a n00b angle, so any tips will help (and no, i wont hold you responsible if i stab myself in the eye with a screwdriver while doing it)
dingaling
tas
Re: power steering pipes leaking bad, any advice? Thu, 15 January 2004 07:20 Go to previous messageGo to next message
that sounds like a complicated problem to workout speakafreaka, but good luck with it.
Ed, thanx for your advice, i like simple advice in a step by step structure, unfortunatly i'm stuck at step 1 :(-
whats the deal with those big 22mm nuts that the power steering lines are connected to. They are tighter then a nuns kunt. And there is no room for a ratchet.
1- take hose off <<I'M STUCK AT THIS ONE
3- hand over money
i'm hopin you or anyone might have a technique or a better tool for the job?
Alchemist
Re: power steering pipes leaking bad, any advice? Thu, 15 January 2004 11:17 Go to previous messageGo to next message
[quote title=dingaling wrote on Thu, 15 January 2004 18:20]They are tighter then a nuns kunt. And there is no room for a ratchet.
quote]
Laughing
dingaling
tas
Re: power steering pipes leaking bad, any advice? Thu, 15 January 2004 13:56 Go to previous messageGo to next message
ok so i finally got the pipes out, took it to enzed, and the guy said he can't fix it! to many bends in the pipe and that his special clamping tool won't work on the shape. FUGIT!
so i said, ok ditch the curly pipe section and just use the two end pipes with one long rubber hose between them. Thus i'll probably lose the cooling characteristics by ditching the steel pipes.
any thoughts on this? is this a really really bad idea?
[Updated on: Sat, 17 January 2004 05:15]
dingaling
tas
Re: power steering pipes leaking bad, any advice? Sat, 17 January 2004 05:16 Go to previous message
bump
first time i've ever used it
Previous Topic:Engine mounts problems!
Next Topic:AE86 whiteline kit. your thoughts?
Current Time: Fri Nov 20 15:55:37 UTC 2026
Total time taken to generate the page: 0.0076789855957031 seconds
