Toymods » Tech & Conversions » MX73 underbelly/front sump dimensions
MX73 underbelly/front sump dimensions Mon, 12 January 2004 01:01 Go to next message
Has anyone measured the underside of an mx73 cressida, namely from the gbox to the x-member, and then the x-member to the sway bar?
OR
Has anyone got a 5mge (maybe 7mge) front sump handy that they could measure.
I've measured up the 1uz front sump, and I need to know how much I have to modify it in order to fit it.
I will be getting under my car next weekend to measure it, but if someone has already done it, that would be ossum.
Cheers ppls
Re: MX73 underbelly/front sump dimensions Tue, 13 January 2004 06:24 Go to previous messageGo to next message
C'mon, somebody has got to have a front sump 5/6/7mge out of a car they can measure?
Bump
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: MX73 underbelly/front sump dimensions Tue, 13 January 2004 09:52 Go to previous messageGo to next message
Here you go mate, 235mm from front of bellhousing to rear of crossmember, the crossmember is 100mm front to back (at it's base), then about 300-310mm from front of crossmember to swaybar.
http://members.optusnet.com.au/pwswinner/DSC03224.jpg
http://members.optusnet.com.au/pwswinner/DSC03225.jpg
http://members.optusnet.com.au/pwswinner/DSC03226.jpg
Re: MX73 underbelly/front sump dimensions Tue, 13 January 2004 13:55 Go to previous message
Thanks Joel, your a champion
I've mocked up what it should look like with the 1UZ sump in there. Looks like I have to knock 50mm or so out of the xmember end. (of the sump that is)
Do I just make the sump deeper?
http://oz-enet.com.au/~peewee/sumps.jpg
[Updated on: Wed, 14 January 2004 00:44]
Previous Topic:leaking oil, gearbox or engine???
Next Topic:4 wire oxygen sensor 4agze
Current Time: Sat Nov 21 01:08:49 UTC 2026
Total time taken to generate the page: 0.0042939186096191 seconds
