| Author | Topic |
Axle tramp on ae86
Mon, 12 January 2004 04:23
Car shakes violently when doing a burnout, rear end jumps around,
how do i fix this?
Re: Axle tramp on ae86
Mon, 12 January 2004 04:52
Maybe your shocks are shot?
Is it lowered? The pinion angle will be all wrong if so. In which case you might want to look at adjustable trailing arms and traction brackets.
Mon, 12 January 2004 05:04
yep its lowered, the shocks look pretty fucking old now that i look at it.
stuffed shocks causes axle tramp?
Mon, 12 January 2004 05:15
Yeah stuffed shocks wont help.
Mon, 12 January 2004 05:59
I've commented on this one before... do a search Actually, just order the adjustable arms and 'traction brackets' from whiteline - solves the axle tramp, improves the handling, worth every cent! Although you COULD make similiar parts if you're good at that kind of thing, and save some $
Mon, 12 January 2004 06:43
mine does the same. blown shocks are the culprit, too bad im too lazy to change them since they're only $15 a piece ;P
jeremy
Mon, 12 January 2004 07:36
| Quote: | The pinion angle will be all wrong if so. In which case you might want to look at adjustable trailing arms and traction brackets.
what do these look like and what is their function
i have short stroke shocks and lowered springs on my car and it has a little tiny amount of tramp
do i need to do the above?
Mon, 12 January 2004 07:45
how much do adjustable arms and traction brackets cost?
Mon, 12 January 2004 07:49
my car is sitting about 10-20mm from the bump-stops with 205's at the rears and i don't have any problems even with the standard worn shocks.. i dunno, maybe your problem could be something else?
Mon, 12 January 2004 10:11
Traction brackets and adjustable trailing arms are just some of the stuff you'll need to fix your car after you've lowered it.
The trailing arms are the 4 arms you have holding the diff housing in place. You really only need to put 2 adjustable ones on, one on each side. Lower or upper.
Traction brackets change the mounting point of the trailing arm on the diff to bring it back somewhere closer to factory geometry. The adjustable trailing arms lets you bring the pinion angle back to factory also.
Mon, 12 January 2004 10:22
ive got similar problems with the hilux diff in mine, gonna have to spend a little on that area I think
Mon, 12 January 2004 10:33
Yeah it's all quite important for a good handling car.
How do you find the hilux diff? I'd have thought in a 900kg car it's a hell of a lot of added unsprung weight.
Mon, 12 January 2004 10:57
At the moment the front is too low with 16's and wheels scrub when pushed hard so havn't checked the handling too much yet.
Its got a 1g in it so overall its a bit heavier anyway.
In the wet it gets sideways without any wouncing, but launching it bounces HEAPS
when it was low at the back the diff use to hit under the car... OUCH
It launches good though not use to this power and an LSD
4000k drop and BOOM
I looked back to a taxi wanting to race and he was a mile back, shocked me
