Toymods » General Car Talk » service questions
The Untouchable
Ballarat
service questions Mon, 12 January 2004 06:20 Go to next message
hey guys,
wondering if you could all pitch in and give me a comprehensive list of all the things you should do to properly service your car. (mines the ta22). just want to know, things to change and things to check. i realise everything can be changed and checked, but um, yeah just stuff like oil and petrol filters, wiper blades Neutral thanks boys (y)
Re: service questions Mon, 12 January 2004 07:00 Go to previous messageGo to next message
wiper blades
change of oil & oil filter (always change the oil filter with the oil)
check brake, clutch and ps fluid levels, top up & bleed if required
check brake pad wear on all wheels
check tyre wear on all wheels (including spare!)
fuel filter if it hasn't been changed in ages, or car has uncertain history
flush & fill radiator (if due, or if uncertain history)
check air filter. Replace/clean if necessary
ummm... almost certainly more
STR8 2.8
Re: service questions Mon, 12 January 2004 07:14 Go to previous messageGo to next message
check plugs and leads
check ignitiong timing
check battery fluid level
Mr DOHC
Re: service questions Mon, 12 January 2004 07:25 Go to previous messageGo to next message
timing belt/chain if needed, or rattly, while in there do the cam/crank seals
do a proper fluid change on brakes, every 50k or so
Re: service questions Mon, 12 January 2004 08:12 Go to previous messageGo to next message
Tyre pressures (including spare)
All belts (aircon, alt, waterpump, p/s, not just timing)
Wheel bearing (check for movement)
Hand brake meat
The Untouchable
Ballarat
icon14.gif  Re: service questions Sat, 17 January 2004 11:02 Go to previous message
thanks boys, ill cover all that
Previous Topic:Previewing Gran Turismo 4...
Next Topic:about profile
Current Time: Tue Oct 20 22:35:09 UTC 2026
Total time taken to generate the page: 0.10862588882446 seconds
