Toymods » Tech & Conversions » 4age Help Needed!!!
de_rift
Wollongong
4age Help Needed!!! Mon, 12 January 2004 08:36 Go to next message
My 4age bigport wont start...
Fuel is working
Spark is working
Compression is low (from 100-130psi but on a cold engine)
Spark plugs are fouled
Before the engine stopped,it was running rich, and had absolutely no power.
I'm thinking that the valve seals are gone, but would this cause the plugs to foul? About a month ago the plugs where in good condition, and the compression was about 140 again on a coldish engine with push down compression tester, not a screw type.
Any ideas?
I am going to take the head off and have a look at it. Luckily I have a complete 100kw engine that I can swap parts with...
Re: 4age Help Needed!!! Mon, 12 January 2004 10:01 Go to previous messageGo to next message
Even if the valve seals were gone it'd still start.
How are you checking you have fuel? Have you confirmed the injectors are actually firing?
de_rift
Wollongong
Re: 4age Help Needed!!! Mon, 12 January 2004 10:08 Go to previous messageGo to next message
I've checked the fuel is flowing from the fuel line...
However the injectors must be firing because you can smell the fuel from the exhaust.
You can also see/smell the fuel on the plugs
Could fouled plugs cause this?
Re: 4age Help Needed!!! Mon, 12 January 2004 10:13 Go to previous messageGo to next message
Yeah if the plugs were wet and fouled enough could cause this.
And spark, I assume you've put a spark plug on the end of one of the hitension leads to check?
de_rift
Wollongong
Re: 4age Help Needed!!! Mon, 12 January 2004 10:17 Go to previous messageGo to next message
yeah thats what I did
Re: 4age Help Needed!!! Mon, 12 January 2004 10:22 Go to previous messageGo to next message
Have you checked timing?
If its got fuel and spark.. No reason it shouldn't start really. Unless of course the ecu is doing something silly and completely flooding the engine.
Scorpion
Menai area of Sydney
Re: 4age Help Needed!!! Mon, 12 January 2004 12:22 Go to previous message
If there is fuel on the plugs it is likely the spark plug is not firing under compression conditions in the cylinder. Can you get hold of another coil to try to see if the current coil is stuffed ? Could also try new plugs.
Previous Topic:Sprinter Installation Queries
Next Topic:camber on ta22
Current Time: Sat Nov 21 01:51:23 UTC 2026
Total time taken to generate the page: 0.087490081787109 seconds
