Toymods » Tech & Conversions » r series engine in a ta22
alex_ta22
Newcastle, Hunter Valley
r series engine in a ta22 Mon, 12 January 2004 10:47 Go to next message
will i have to get this engineered, as this engine did come out in this car in america? also if i cant find a proper x-member what are my options in getting one custom made?
is shortening an ra23/28 x-member an option?
people100
Rocklea qld
Re: r series engine in a ta22 Mon, 12 January 2004 11:37 Go to previous messageGo to next message
just get your mounts moved. doesnt cost much especially if u do it yourself. Yes i think u do need it engineered as a ta22 has a 1600 i think as standard.
Re: r series engine in a ta22 Mon, 12 January 2004 11:47 Go to previous messageGo to next message
Not that simple I'm afraid, the TA22 and RA23 crossmembers are a totally different shape hence you'll need a different sump and oil pickup. You'll also have clearance problems with the radiator and the transmission will have to be changed as well.
What's the point though? Buy an RA23, they're cheap. Or get a 2T-G and bore+stroke it to 2.0 litres.
alex_ta22
Re: r series engine in a ta22 Mon, 12 January 2004 11:54 Go to previous messageGo to next message
what if i could get a ra21 x-member, technically it is all factory, would i still need an engineers certificate
Re: r series engine in a ta22 Mon, 12 January 2004 11:56 Go to previous messageGo to next message
Read above! The engine wont fit unless you do mods to the radiator support!
alex_ta22
Re: r series engine in a ta22 Mon, 12 January 2004 12:03 Go to previous messageGo to next message
never mind too much trouble
Re: r series engine in a ta22 Mon, 12 January 2004 12:05 Go to previous messageGo to next message
Yep way to much trouble for the gains. Been there done that Sad
Re: r series engine in a ta22 Mon, 12 January 2004 12:07 Go to previous messageGo to next message
The fact that an R series engine existed in another car in another country is completely irrelevant to the local authorities. That's not to say you couldn't get it engineered with a bit of effort.
As above, not worth the bother though.
blackRA28
adelaide
Re: r series engine in a ta22 Mon, 12 January 2004 14:47 Go to previous message
Um well actually courtesy of RA28_midge i have a document from the RTA here in S.A. stating that any toyota engine up to and including 2 litres, naturally asp, can be put into celicas from 71 thru 77.(and possibly later, but the rules change slightly..) As long as it meets the 2 page list of constraints..
A few people here in SA have been thru regency successfully with 18R-G conversions in RA2x series, but with the case of a TA22 you may need to specifically ask them of the engineering guidelines as to xmembers, gearbox mounts etc.. Because technically in their rules it is allowable to put an 18r series motor, or 3SGE for that matter Twisted Evil ,into a ta2x/ra2x and just need a regency inspection.. ie emmisions, suspension, small things, body etc..
But yeah, for the effort, you may as well mod the xmember for a 3T-GTE or 3S-GTE and snyper it/engineer it with slight brake mods, etc.. would be much more bang for buck/bother..
Previous Topic:Incorrect RPM Readings
Next Topic:Question to KE30 Owners?
Current Time: Sat Nov 21 00:29:55 UTC 2026
Total time taken to generate the page: 0.0066580772399902 seconds
