Toymods » Tech & Conversions » Shifter conections on an aw11 4age
fatmr2
Shifter conections on an aw11 4age Mon, 12 January 2004 20:12 Go to next message
Im pulling out my 4age in my mr2 and im not sure how to undo the shifter cables? They sit on this bracket that i could take off but it's a bit of a tight spot.
Is there another way?
feral4mr2
Bundaberg, Qld.
Re: Shifter conections on an aw11 4age Mon, 12 January 2004 21:42 Go to previous messageGo to next message
Freak it is a little tight. there are flat metal plates holding the cables into their mount, simular to the ones that hold brake lines in. (the flat U shape bits).
find the edge on the plate and work it with some long nose pliers until it comes off and then pull the cable through the mount hole.
you have the cables off the gearbox linkages already?
fatmr2
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 01:11 Go to previous messageGo to next message
Your a life saver feral Very Happy
I was there last night thinking how the hell, cause i didn't want to break anything Smile
Also, to pull the engine out do i have to disconnect the drive shafts? as i have the car on ramps .
And how do you lift the car up to get the engine out from underneath?
midnight
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 01:54 Go to previous messageGo to next message
if you dont have a hoist or jack big enough just ask around 4 of your mates and pick the rear end up.... Very Happy
feral4mr2
Bundaberg, Qld.
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 02:59 Go to previous messageGo to next message
Freak i had a block n tackle fixed to the roof above the car, i used it to lower the engine to the shed floor (which i had a tarp on the drag it out with), then lifted the body up with the block n tackle and dragged the engine out.
as for the drive shafts, i took mine right off the gearbox/axles before i dropped the engine. makes it a lot easier to work on and manouver the thing with-out them there.
Smile
fatmr2
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 03:09 Go to previous messageGo to next message
I have a hoist and block and tackle but i just dont know where exactly on the car i'm supposed to hook it onto?
feral4mr2
Bundaberg, Qld.
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 03:16 Go to previous messageGo to next message
Freak after i lowered the engine, i carefully ran a chains around the lower suspension arm mounts and lifted it up up and away..... Shocked
oh well, lunch is over. bye Smile
fatmr2
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 04:02 Go to previous messageGo to next message
Once again, thanks heaps Very Happy
Joshstix
Toymods Vice President
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 04:59 Go to previous messageGo to next message
Here's a bit of a pictorial on how to remove an AW-11 engine. This is the method I used and it worked very nicely.
http://board.mr2faq.com/showthread.php?s=&thre adid=55064
fatmr2
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 09:38 Go to previous messageGo to next message
Thanks peoples, you should be happy to know that i dropped the motor out tonight. Easy as.
Its just sitting on the hoist legs for now. I'll lift the car over and get it out tomorrow.
midnight
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 10:39 Go to previous messageGo to next message
when you get the donk back in we should get a sydney aw11 cruise happening... Very Happy
fatmr2
Re: Shifter conections on an aw11 4age Tue, 13 January 2004 20:21 Go to previous message
Hey, that sounds cool. I've never met anyone else with an aw11 Smile
It would be good to have a look at everyone elses cars too.
I'll need about a week or to though Smile
Previous Topic:1GGTE in to Hilux need answers about std ECU
Next Topic:4age oil pump mods
Current Time: Sat Oct 24 01:38:38 UTC 2026
Total time taken to generate the page: 0.004863977432251 seconds
