Toymods » The Outhouse » power consumption of halogen lights
Lambolica
Northwestern Sydney
power consumption of halogen lights Tue, 13 January 2004 00:14 Go to next message
Just a question ion power consumption of halogen lights compared to say a normal 60W globe, I read somwhere that somthing like 1 60W globe equates to approx 7 (or somthing) halogen globes.
Can any body confirm or denie this as I can't find the webpage I read this on.
I need to justify my wanting to use 20 or so low voltage lights in the garden to my missus Crying or Very Sad
Re: power consumption of halogen lights Tue, 13 January 2004 00:19 Go to previous messageGo to next message
nope - a 20w bulb regardless of kind of technology consumes 20W - a halogen is more efficient at converting electrical energy to light - but it gives off more heat.
if you're after low-energy you gotto go low-wattage fluro
e.g. a 11w fluro bulb from ikea produces similar amount of light to 60w incadescant bulb
note: if you're comparig 60W 240V versus a bunch of 12V lamps - you need to work out the 240v load when the bulbs are all on - not the 12V load - what does the transformer say it needs to power the set of low-voltage bulbs?
[Updated on: Tue, 13 January 2004 00:21]
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Tue, 13 January 2004 00:31 Go to previous messageGo to next message
The transformer I'm looking at is a 240V -> 12VAC 150W which will be powering between 5 and 7 20W Halogen globes
It's output is 12.5 Amps.
Re: power consumption of halogen lights Tue, 13 January 2004 00:57 Go to previous messageGo to next message
if you're using 7 x 20W (140W in total) halogens then they'll require 11.2A (@12VAC) to keep them lit.
one more bulb and you'll exceed capacity of transformer
there will be loss in the transformer hence the 10W headroom
i think someone with elec engineering background would know (with more precision) how much energy would be lost in the transformer
charles
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Tue, 13 January 2004 01:01 Go to previous messageGo to next message
What about bad earths? Razz
So one would be better to run the transformer at its rating
ie 5 x 20W + 1 X 50W halogens = 150 to get (maximum) light??
Re: power consumption of halogen lights Tue, 13 January 2004 02:00 Go to previous messageGo to next message
tis up to you - expect the transformer to run slightly warm if at 100% rated duty
but if it were my garden i'd run lots of low W bulbs - and use proper floodlights (240V quartz halogen) for floods. personally i don't like big, bright, direct lighting.
as for earths - dunno - ask Cool1 Laughing Laughing
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Tue, 13 January 2004 03:15 Go to previous messageGo to next message
That's my plan, to run low voltage lights basically to light up the driveway at night a luminate the path to the back door.
I'm not after daylight at night. And I'll have 2 240V flood lights on the pergola for Day/Night Backyard Cricket.
Squid
Re: power consumption of halogen lights Wed, 14 January 2004 04:24 Go to previous messageGo to next message
A transformer will have no problem running at a light load, however if you exceed the wattage you draw too many amps and the coils melt and you start a fire and ruin your science project (not that this has ever happened to me or anything). Only drawin 140watts from a 150watt transformer will do no harm.
By law the output rating of the transformer should be after any internal losses. So you can draw 150w from that transformer without risking a fire. (there is normally an amount of tolerance to go above the rating, but that is pretty dangerous.)
Re: power consumption of halogen lights Wed, 14 January 2004 09:15 Go to previous messageGo to next message
Being an AC supply it shouldnt get to warm operating at its full rated output.
How much are you looking at spending on the power supply? Dont limit your self to the power supplies that are marked for garden lights. Because there are other types that will allow use the amount of lights you are wanting to use.
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Wed, 14 January 2004 21:55 Go to previous messageGo to next message
I'm looking a Jaycar power packs of which I'll prolly need 3 or 4 to run the number of lights I'm planning to run. at about 70 bucks apiece.
You have another option there cool1?? Smile
Re: power consumption of halogen lights Thu, 15 January 2004 03:36 Go to previous messageGo to next message
As long as you are keeping the supply inside you could/should just buy a big DC power supply. I have some 25Amp continuous switch mode power supply's which would do the job very well.
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Thu, 15 January 2004 03:57 Go to previous messageGo to next message
The supply will be outside but under cover and enclosed in a built in BBQ (next to bar fridge and Irrigation timer system)
Your starting to lose me on the power supply stuff:blush:
25Amps meaning that it can run more Lights that draw (insert halogen light current here) Amps
ie. light draws (say) 0.25 Amps / 25 amps = 100 lights??
Electronics is not a strong point of mine Embarassed
I cause bad earths.
what does a typical pond pump run off?? 240V or 12/24V
If what you're saing is applicable could I run a pond pump off the power supply as well as lights??
Re: power consumption of halogen lights Thu, 15 January 2004 05:45 Go to previous messageGo to next message
pond pumps are usually 240V AC powered.
keep pond pump separate to lighting power so it doesn't fry your lighting power supply when you accidently dig up the power line - plus mixing inductive loads (e.g. motors) and fixed load devices (incandescent bulbs) isn't a great thing. i don't mean a separately fused circuit, just not from the same power supply (if you are able to find a 12V pump)
as for your lighting power requirements, a 12V 20 Watt halogen requries about 1.7Amps to keep it lit. So a 25Amp switched-mode DC supply could keep 14 of them lit.
simple equation to work out DC current requirements: Watt = Volts * Amps
if you want to work out AC current requirements it gets a little more confusing.
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Thu, 15 January 2004 05:53 Go to previous messageGo to next message
Yeah that all sounds familiar I even recognise that formula, and that basically means I haven't yet killed off all my brain cells from school. So off to the pub.
What are the details of these 25Amp continuous switch mode power supply's Do Jaycar sell them (so I can see what you're talking about?
Pricing?
Re: power consumption of halogen lights Thu, 15 January 2004 11:58 Go to previous messageGo to next message
Jaycar dont sell these. The ones I have are about $1200 new. I normally sell them for about $400 second hand.
But dont get me wrong, I'm not saying to buy one of mine. I'm just saying that there are other power supplies you can use for your lights.
Lambolica
Northwestern Sydney
Re: power consumption of halogen lights Thu, 15 January 2004 23:19 Go to previous messageGo to next message
I'm pretty much open to options. somthing to look into.
Ta Cool1 Smile
Re: power consumption of halogen lights Fri, 16 January 2004 06:43 Go to previous message
No worries Smile
Previous Topic:Going Away
Next Topic:you just cost me 20 dollars!
Current Time: Sat Oct 17 21:24:15 UTC 2026
Total time taken to generate the page: 0.0075678825378418 seconds
