Toymods » Tech & Conversions » simple welding Q
cri_ag
northern beaches
simple welding Q Tue, 13 January 2004 07:09 Go to next message
what sort of welder would one require to perform a cut and shut job on a fwd 100kw 4age intake man to make it suit rwd?
onejayzed
Re: simple welding Q Tue, 13 January 2004 07:26 Go to previous messageGo to next message
TIG.
it's alum/alloy, so you'll need a more precise heat for the weld which only TIG can offer.
from memory the range is 650 - 680 degC Shocked
because it's aluminium, you will be best off using a TIG welder.
aluminium welding is always a bit of a bugger, and experienced hands will always do a better job....
bmak
Re: simple welding Q Tue, 13 January 2004 08:12 Go to previous messageGo to next message
TIG would be easiest if you can use 1.
otherwise i go for oxy next & then MIG.
cri_ag
northern beaches
Re: simple welding Q Tue, 13 January 2004 10:20 Go to previous message
excelent thanks guys
Previous Topic:FM Radio intereference
Next Topic:Aircon Brackets
Current Time: Fri Nov 20 23:12:01 UTC 2026
Total time taken to generate the page: 0.0056469440460205 seconds
