Toymods » Tech & Conversions » engine building
Flogbag
Sydney (Campbelltown...!)
engine building Tue, 13 January 2004 11:57 Go to next message
hey everyone
would this work??
i want an agressive N/A motor for my sprinter made to a 4age layout as i dont want to go to the hastle of engineers with a gze or the hastle of water line and dizzy mods with a 20v so here are my thoughts...
gze block as it has forged pistons already...
86kw head as it has bigger valves n ports and i already have one
288" cams (new valve springs)with some head work
compression raised to bout 10 - 11 :1 (somewhere round there)
rwd intake manifold without the tvis plate and rwd throttle body (quad's adapted later on but)
gze DLI with twin coils hooked up with
microtech comp using a map sensor setup...?
**has anyone done anything like this b4??
***is it possible to use the gze block with 86kw head? wats the compression ratio like when this is done?
anyone got anything to add, thoughts, ideas to set me in the right direction...
Flogbag
engine building Tue, 13 January 2004 12:05 Go to previous messageGo to next message
is it possible to just use the gze but without the supercharger just changet the compression put my cams in and different intake maifold???
how much power can the gze with stock internals take from a n/a setup?
sorry bout the long post but these are just my last big questions needed to decide on wat motor ill be putting in
thanks for any help u can give guys...
Dodgy_Haro
Re: engine building Tue, 13 January 2004 12:11 Go to previous messageGo to next message
Using a GZE block may not be the best choice to build a N/A engine as 4AGZE's generally have lower compression to allow force induction from either a supercharger or turbo.
Perhaps you should be looking at a redtop 100kw or 20 valve block as these were made to run with higher compression standard?
Then again, it's probably been done but as to the results ... Confused
purpleminiep
Mentone
Re: engine building Tue, 13 January 2004 12:15 Go to previous messageGo to next message
Late gze 7 rib blocks are the same a 100kw and 20v blocks. Its the pistons that are forged and are low compression. Useless for a na motor. Its probably best to use a 100kw block and get a set of cams for it and mabye a port job. When your rebuilding it get everything balanced including crank flywheel and crank pulley. Some people say it wont make any difference but it carnt hurt at high revs and its cheap.
Brad
Dodgy_Haro
Re: engine building Tue, 13 January 2004 12:30 Go to previous messageGo to next message
purpleminiep wrote on Tue, 13 January 2004 23:15
Brad
Ah ... cheers for that - yeah, not the block but the internals which makes the difference.
Guess you can draw on either specification from a Formula Atlantic or Group A spec engine to get an idea of how to go things the N/A way ...
May just be cheaper to go 20 valve way IMO ...
onejayzed
Re: engine building Wed, 14 January 2004 01:41 Go to previous messageGo to next message
why wouldn't you use the GZE block (with the oil squirters) but with higher comp pistons? you'd be nuts not to - it would be a very strong bottom end.
why does he 'have to' use the GZE pistons and rods with the GZE block?
GZE-STYLE
Camden
Re: engine building Wed, 14 January 2004 04:00 Go to previous messageGo to next message
You know that the 20v have oil squirters aswell? Its a very strong bottom end when used with forced induction. Why would you bother getting a gze bottom end and changing pistons etc when the 20v is exactly the same?
de_rift
Wollongong
Re: engine building Wed, 14 January 2004 04:06 Go to previous messageGo to next message
The only difference between the 4agze and other engines is the low compression pistons the rest is the same. Oh and all 4age pistons are forged.
Bigport heads do not have bigger valves, only bigger ports.
A rebuilt bigport engine will go just as hard as a rebuilt smallport, the differences are minor once you start using aftermarket parts in them.
purpleminiep
Mentone
Re: engine building Wed, 14 January 2004 04:14 Go to previous messageGo to next message
There are different rods for all 4age variations. 88kw, 100kw, ZE, blacktop, silvertop are all different.
Brad
Flogbag
Re: engine building Wed, 14 January 2004 05:35 Go to previous messageGo to next message
i can get a complete 20v motor minus computer with a cut up loom for $595 and then a microtech computer with handset for $1000
id like to go this way but i dont want to cut the firewall id be willing to bash it a lil. i know u can get custom water outlets and a kit to put the dizzy at the front but for the price id pay for that i coud get a 100kw motor and wack that in with cams head work and a complete rebuild...
could i put a DLI setup on the 20v? with gze coils or something? does anyone know and websites that supply these and know if they will work with the microtech and 20v motor? if i could set it up like that id be more willing to attemp the conversion
Chris Davey
sunny coast, qld
Re: engine building Wed, 14 January 2004 05:47 Go to previous messageGo to next message
IMO just get a GZE or a 20v and get some bigger brakes for engineers cert.
Why wouldn't you want bigger brakes anyway?
de_rift
Wollongong
Re: engine building Wed, 14 January 2004 07:02 Go to previous messageGo to next message
Flogbag wrote on Wed, 14 January 2004 16:35
AFAIK you can just fit the complete water pump housing/pump from a 4ac to the 20v, and have the water outlets where you need them.
If your getting a microtech, you don't need the dizzy. You'll have to spend about $1200 on the microtech including coils and ignitors though. From there you just need some sort of cranktrigger/angle sensor. Just about anything you can fit to the engine the microtech will run...
sideshow
Re: engine building Wed, 14 January 2004 07:44 Go to previous messageGo to next message
yer by the time u get the 4age runnin anywhere as near as the 4agze u woul dspend heaps more and prob wont be as reliable
ive seen afew sprinters with gzes and they seem pretty simple
if u r goin to do cams and headwork seems u have alot of money
still a gze will prob be better of the mark
[Updated on: Wed, 14 January 2004 07:45]
Re: engine building Wed, 14 January 2004 08:44 Go to previous messageGo to next message
de_rift wrote on Wed, 14 January 2004 15:06
you sure on that? send me a 4AGE piston and i'll check for you.
are the rods the same?? i was under the impression that GZ had thicker rods, and the 20V had lighter rods.
so you think that the port size is a non-issue once you have same cams, compression etc?
Flogbag
Re: engine building Wed, 14 January 2004 09:07 Go to previous messageGo to next message
[quote title=de_rift wrote on Wed, 14 January 2004 18:02]
crank angle sensor? wat type has anyone ever done this? wat type have they used?
and about the water pump from a rwd wat do i do with that, i mean from the back of the pump it goes straight in to the head (would i go from the pump to the bottom of the ratiator then the one that goes into the head go to the top of the radiator?) and then the outlets at the back near the firewall...?
theres the artical in the gallery about fitting a 20v in rwd trim properly but its a little vaige. anyone got pics....
de_rift
Wollongong
Re: engine building Wed, 14 January 2004 10:56 Go to previous messageGo to next message
oldcorollas wrote on Wed, 14 January 2004 19:44
yeah your right the rods do differ.
I think I saw a post here of someone that cut a 4age pistons in half revealing the tell tale grain structure of a forged piston.
Flogbag
Re: engine building Wed, 14 January 2004 11:37 Go to previous messageGo to next message
guys i have come to my conclusion thru many hours of searching the web...
im going to buy a 20v!!
adapt the cooling system using a RWD water pump like in the conversion "how to fit a 20v in rwd trim properly"
use the 20v dizzy minus cap and rotor and get a platic cap of a gze or similar to cover the top of dizzy i seen a 1g dizzy with a cap also at an import yard that looks kinda the same
buy a microtech
buy a low pressure lift pump to pump into a 600ml under floor mounted surge tank then out to a vl or similar high pressure pump down the original steel fuel lines to the motor
custom extractors with zorst work out dimentions etc later
and TRUMPETS with socks.... 4 that great quad throttle body sound
sound like a good plan?
EVOSTi
cambo
      no
Re: engine building Thu, 15 January 2004 05:44 Go to previous message
sounds like a good plan if you can afford it. but the question is, why go through all this hassle for a 20V when the gze conversion is far simpler, and gives better performance on the road? GZE for road, 20V for track imo. besides, when you get sick of the GZE power, you already got half the goods for the GTE. and you need an engineers for the 20V anyway. just do like i do and dont get one Smile
Previous Topic:Jumpy Idle
Next Topic:fly cutting pistons
Current Time: Thu Nov 5 04:43:29 UTC 2026
Total time taken to generate the page: 0.16432809829712 seconds
