Toymods » Tech & Conversions » Oil vs Water temperature
demuire
Ipswich
Oil vs Water temperature Tue, 13 January 2004 14:40 Go to next message
Which would you consider more useful?
Most people seem to buy a water temperature gauge, regarding an oil temperature as a bit extreme.
On the other hand, the stock cluster already has a (rather inacurate) water temp, and also the oil temperature would be a clearer indication as to how hot the engine is actually running.
The gauges appear to be about the same price, and I have the option to buy either...
Hmm...
What are your opinions?
Re: Oil vs Water temperature Tue, 13 January 2004 16:44 Go to previous message
well, the way i see it, your water is cooling your oil, as the oil will be at a higher temp.
you need a water temp gauge to stop the water from boiling.
you need an oil temp gauge to stop the engine from running too hot.
if you are going to run yur car hard, the oil temp will (prolly) rise faster than water temp. and when the oil gets too hot, the bearign oil film can break down....
oil.
Previous Topic:4age oil pump mods
Next Topic:leaking oil, gearbox or engine???
Current Time: Sat Nov 21 01:19:53 UTC 2026
Total time taken to generate the page: 0.0039150714874268 seconds
