Toymods » Tech & Conversions » HELP, NOISE on take off.
Spanktown
Inside a giant turbo (syd...
icon13.gif  HELP, NOISE on take off. Tue, 13 January 2004 23:50 Go to next message
I know i posted this about a week or more ago but here goes. AW11 MR2 SC. When at a stand still and only from a stand still when taking off either in first or second (for testing purposes) A loud Scraping/grating noise emits from around the gearbox/clutch. I took the car out to 2 different clutch specialists and both times it didnt make the noise anywhere near as bad as it does normally, to just today it hardly made any noise at all. The clutch place told me it has plenty of life left in it and i should just keep driving it. I get it home and its making the noise loud as again. They say its not the thrust bearing.......... so any help? Embarassed
[Updated on: Wed, 14 January 2004 04:50]
Spanktown
Re: HELP, NOISE on take off. Wed, 14 January 2004 04:52 Go to previous messageGo to next message
Re: HELP, NOISE on take off. Wed, 14 January 2004 05:12 Go to previous messageGo to next message
spigot bearing in centre of flywheel? tho - it should be noisy at all times if stuffed
if it's only two gears, then could be:
synchros for those gears
needle-roller bearings for layshaft in gearbox flogged out at 1-2 end
does this happen as the clutch is slipping (while clutch pedal is moving from disengaged to engaged) or after is in gear and under power?
clutch would only be culprit if it's while it's slipping -if its fully engaged, alook elsewhere.
also, have you done a slippage test on the clutch, find a steep hill and drive up it 1st second and low revs then floor it, if slipping engine will overspeed compared to actual accelaration.
have you gone lo-tech with this? get under car and look for new scars/scratching on/near exhaust pipe - particularly near the gearbox - i once thought my engine had developed vibration problem (e.g. clutch/flywheel rooted or loose) turned out to be exhaust vibrating on end of bellhousing - was not obvious from looking thru engine bay, but from undeneath was visible
Spanktown
Re: HELP, NOISE on take off. Wed, 14 January 2004 12:57 Go to previous messageGo to next message
clutch isnt slipping at all, tested that. no new scratches, nothing rattling against anything else. This gearbox doesnt have a spigot bearing! argh thanks tho, is there anything in the gearbox that could do it, ie it only does it on take off ie more load on box/clutch?
Re: HELP, NOISE on take off. Wed, 14 January 2004 13:25 Go to previous messageGo to next message
i'd say it's a bearing somewhere - as it's only those two gears, i'd point the finger at the synchros for those gears. do you get any noises if gently cruising in 1st or second?
what about other parts of the drivetrain? diff? drive shafts?
Spanktown
Re: HELP, NOISE on take off. Wed, 14 January 2004 13:27 Go to previous messageGo to next message
no the noise is made in any gear you take off from a stand still in... ive tried reverse 1st and second, if the clutch is engaged it doesnt make any noises....
when you drive and back off the gearbox makes a slightly audiable noise ? what could it be in the gearbox?
Re: HELP, NOISE on take off. Wed, 14 January 2004 13:45 Go to previous messageGo to next message
just a thought - you car is mid mounted engine - so are the engine/gearbox mounts alright?
if they're stuffed, the engine could be moving around too much under load (or backing off after applying load) and something it hitting something else (drivshaft on fixed thing, or engine hitting chassis or...)
Spanktown
Re: HELP, NOISE on take off. Thu, 15 January 2004 00:09 Go to previous message
no its not the mounts, maybe something in the gearbox? spinning type noise, but the bad thing is the initial clutch gripping noise.
Previous Topic:1ggze V 1ggte
Next Topic:1G info needed
Current Time: Sat Nov 21 05:38:21 UTC 2026
Total time taken to generate the page: 0.010048151016235 seconds
